Crx wont start
Old Jan 31, 2012 | 01:59 PM
Efhatch277's Avatar
Default Crx wont start
Problem is my 88 crx wont start, put key in ignition turn with clutch depressed and nothing, no clicking or anything. Thought it was the clutch safety switch, so I bypassed that still nothing. Checked main relay, and all grounds, car can be push started. Only other thing i think it can be is the ignition itself but not sure, all help is greatly appreciated. thanks in advance
Old Jan 31, 2012 | 04:48 PM
lazlong's Avatar
Default Re: Crx wont start
Is the battery good? Did you actually test the main relay? Do you have power when you turn the ignition ON?
Old Jan 31, 2012 | 05:44 PM
Efhatch277's Avatar
Good battery, new relay, all power
Old Jan 31, 2012 | 08:44 PM
lazlong's Avatar
Jump the starter from the battery to see if it's bad. If the starter is good I'm thinking bad ignition.
Old Jan 31, 2012 | 10:00 PM
mizle's Avatar
maybe a ground not good, check those out thats where i usually start at.
Old Feb 1, 2012 | 10:20 PM
tyvtec23's Avatar
the starter sounds like its shot
Old Feb 1, 2012 | 10:57 PM
KINGVEM^^ED6's Avatar
X2
Old Feb 2, 2012 | 01:12 AM
Alex_S's Avatar
Try tapping the starter with something
redefsir
19
Jan 28, 2010 08:46 AM
CRX831
Dec 7, 2009 11:53 PM
Defiant_dc
Aug 14, 2009 04:29 AM
bywaters
16
Jan 14, 2009 05:04 PM
curiousgpnoy
Jun 25, 2003 08:43 AM
