Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Idle Air Control Valve
Old Jan 30, 2012 | 07:22 PM
ShatiaNichols's Avatar
Icon3 Idle Air Control Valve
I drive a 94 Honda Accord, how would I easily check the idle air control valve in order to see if it needs to be replaced
Old Jan 31, 2012 | 04:18 AM
jmarshall098's Avatar
Default Re: Idle Air Control Valve
Usually the car runs rough with a dirty or faulty idle air control valve. The best way to check for proper working of this valve is to pull it off from the throttle body and perform a resistance test to check that the valve resistance and the voltage.
Old Feb 4, 2012 | 10:15 PM
D-JET's Avatar
if you dont have fast idle problems, high idle, or idle hunting then its fine.
Old Feb 23, 2012 | 04:54 PM
rocketcity's Avatar
I have had the same problem & was able to clean the IAC valve with throttle body cleaner.
Old Feb 24, 2012 | 05:02 AM
maystg's Avatar
my 97 Accord idles at 500 sometimes and is usually rough. Would this be an IACV related issue?
Gr8ride82
Jan 26, 2015 04:31 PM
zedjr
Nov 3, 2012 08:24 PM
ShatiaNichols
Jan 31, 2012 08:15 PM
ATS*Mark
16
Feb 22, 2004 01:00 PM
