Tips on reducing discoloration?
Old Jan 30, 2012 | 02:16 PM
ROOKind's Avatar
Default Tips on reducing discoloration?
http://rookind.com/mbrace.html
Check out this picture of our brace. Any tips on how to reduce the discoloration of the welds on stainless? We have spent some time making them as clean as possible, but could use some feedback on any additional tips.
Old Jan 31, 2012 | 02:59 AM
Boosted_B_Series's Avatar
Default Re: Tips on reducing discoloration?
Can't get the pics to enlarge on my phone
Are you having trouble with them turning grey or colorful like a rainbow?
Are you using a gas lens?
Old Jan 31, 2012 | 08:58 AM
ROOKind's Avatar
We are using a cup. And the problem is the browning that extends away from the weld.
Thanks for the reply!
Old Jan 31, 2012 | 05:55 PM
frostyrb's Avatar
walter makes a kit that removes all color from stainless welds. you can also use a pickling gel.
Old Jan 31, 2012 | 08:19 PM
rjones's Avatar
Pickling gel.... Look into it, but also look at the negative side of pickling. I would say leave it that way it looks good.
Old Jan 31, 2012 | 10:27 PM
FaceTuned's Avatar
Turn the postflow up.
Old Jan 31, 2012 | 10:31 PM
SlowReaction's Avatar
Gas Lens, Big cup, longer post flow, if you have a pulse function use that to reduce the amount of heat you put into the workpiece. I dont think it looks bad but if you dont like coloring give those thing a try.
Old Feb 1, 2012 | 10:23 AM
ROOKind's Avatar
Definitely gonna do this. Seems like the pickling gel is going to require some brushing and everything is already at the finish i want it to be. I will test some out and see how it goes. Also part of it that is discolored has our laser etched logo on it and im worried that the acid from the pickling will damage the logo. But only one way to find out .
Hopefully at some point i can get in touch with someone locally to check out one of the Walter kits.
Thanks for the replies everyone!
Old Feb 1, 2012 | 12:35 PM
EJAYATE's Avatar
I Deliver
Bigger cup or weld in a purge chamber. When have one of those walter acid machines for removing the color from stainless. Works like magic.
Old Feb 1, 2012 | 06:59 PM
ELIDA9's Avatar
ROOKIND ! ! ! Love their products and service
DC47A
Welding / Fabrication
Sep 9, 2011 08:20 AM
sdubfid
Jan 12, 2008 06:54 PM
hunghimself
17
Nov 21, 2004 06:56 AM
GroundZer0 336
Nov 11, 2003 07:16 PM
