ecu change
Old Jan 30, 2012 | 08:08 AM
ahenscheid's Avatar
Default ecu change
What do i need to do in order to put a p28 ecu in my f22b1 and everything functioning good.
Old Jan 30, 2012 | 08:21 AM
hondamark35's Avatar
Default Re: ecu change
I'm curious to know what your purpose for doing this is. made modifications to the F22B1?
you will need to chip the ECU and then have a chip burned with the base F22B1 ROM. If significant changes have been made, it would be in your best interest to then have the car tuned on a dyno.
Old Jan 30, 2012 | 09:31 AM
bdmlilburn's Avatar
what year is your car first of all. you will need a obd2 to obd1 conversion harness. check out rywire.com. give them an email and they will tell you everything you need to get started with tuning and if you even really need to spend the money on it
Old Jan 30, 2012 | 11:30 AM
nus_dogg's Avatar
All you have to do is swap pin A6 and A11 at the ECU connector to run a P28 ECU. They're backwards on the 5th Gen Accors. But the P28 has to be chipped and equipped with the right base map for your motor to run properly. Then get a dyno and tuned for healthy maximum power.
Old Jan 30, 2012 | 12:30 PM
ahenscheid's Avatar
alright so i planned on doing this same time i boost so ill just need to keep saving and do all at once so i dont need to tune twice. i was just gonna do this in my spare time but if it requires tuning ill wait
Old Jan 30, 2012 | 01:31 PM
nus_dogg's Avatar
Yes, boosting requires tuning.
Old Jan 30, 2012 | 10:06 PM
ahenscheid's Avatar
Yeah i know boosting requires tuning i was gonna do the ecu sometime soon but im just gonna wait till i have money to boost and dont waste money on tuning twice
b20vdelsol619
Aug 23, 2008 11:49 AM
em1gangsta
Mar 1, 2008 11:04 PM
bOOsT-FeIn
Jul 9, 2007 02:20 PM
Flava
Aug 2, 2006 08:09 AM
gser67
Dec 22, 2004 07:37 PM
