Strange eletronic issue 89 ef
Old Jan 29, 2012 | 09:58 PM
Broke_not_built's Avatar
Default Strange eletronic issue 89 ef
Friend hit a dip alittle to hard in his ef, and now the lights and cluster is all screwed up. We`ve been at it for the past day and cant figure it out. fogs work but HIDs just flicker. when the brake is pressed everything dims and the tach stops working. Hazards make the tach flicker. and we get a cel when the lights are switched on. any ideas?
Old Jan 29, 2012 | 10:03 PM
88HATCH(:'s Avatar
Default Re: Strange eletronic issue 89 ef
mine was doin something similar , check the power wire that goes from the altenator to the fuse block , make sure its not all torn up .
also main relay .. fuses .. altenator .. check grounds ? lots of things it could be .
Old Jan 29, 2012 | 10:09 PM
Thanks I`m gonna try the alternator tomorrow, but everything else seems good grounds are ok no blown fuses
Old Jan 30, 2012 | 07:00 AM
BiGZ's Avatar
And clean the thermostat ground from engine harness! (hondas act very stupid when they're dirty/corroded)...
CIVIC9922
Feb 22, 2013 08:49 PM
netfreak
Sep 19, 2010 05:36 PM
IntegraLova
Mar 25, 2008 08:50 PM
"Pysa"
Oct 13, 2007 07:48 PM
trrbl1bmx
Aug 19, 2006 02:31 PM
