No power to walbro fuel pump
I have a 99 civic SI. I'm in the process of turbocharging it, I just installed a walbro 255 fuel pump. After the install, there isn't any power to the pump. I can run a hot wire straight to the pump and it works fine. Any suggestions? I'm doubting the main relay could go out over night, and I want to stay away from running the pump off a toggle switch.
thanks
thanks
ran a small jumper from one of the wires with power to the wire that powers the fuel pump and it kicked on. Took apart the main relay and there is a little corrosion on the board so thats most likely the problem.
jvans04
Jul 24, 2005 04:49 PM
insomniac791
Jan 22, 2004 04:23 PM
