99-00 si pulley kit fit 99 itr?
my friend is getting a good deal on a 00 civic.aem pulley kit. it includes both powersteering and alternator.pullies. would these fit.the original integra powersteering pump and alternator? any possible.size differences? i
It should fit with no problems. Those are underdrive pulleys so the power steering is going to be less effective at lower RPM's and your lights will be dim. Just a heads up if you are thinking these will make more power.
They will actually be dimmer and noticeably dimmer. I've actually yet to figure out why these are even boughten. I can guarantee you won't notice a difference in actual engine power and I'm not even sure if a dyno could either. Figure a dyno doesn't produce consistent runs back to back. The number usually ranges at least .3 and on a high HP car it could be a few HP.
Achenar
May 7, 2008 07:54 AM
