WA ***00 civic 4 door k20***
UP FOR SALE IS MY 2000 HONDA CIVIC 4 DOOR EX
EXTERIOR:
CLOVER GREEN PEARL (CGP) ORIGINAL PAINT
OEM CIVIC TYPE R HEADLIGHTS (6K HID)
OEM CIVIC VI-RS THIN SIDE MOLDINGS
OEM CIVIC VI-RS WINDOW VISORS
OEM HONDA SUN ROOF VISOR
OEM RAYBRIG CLEAR FOGLIGHTS
CHARGESPEED FRONT LIP PAINTED CGP
INTERIOR:
OEM CIVIC TYPE R RED CARPET
OEM CIVIC TYPE R SRD RECAROS
ORIGINAL TAN INTERIOR (DASH AND DOOR PANELS ETC)
NARDI DEEP CORN BLACK SUEDE WITH RED STITCHING STEERING WHEEL
NRG QUICK RELEASE AND SHORT HUB
RE-WRAPPED HEAD LINER AND SUNROOF LINER (RED SUEDE)
ARC BURNT TITANIUM SHIFT ****
AUDIO:
PIONEER INDASH DOUBLE DIN
INFINITY SPEAKERS ALL AROUND
WHEEL/TIRES & SUSPENSION:
16" DESMOND EVO REGAMASTERS (RE-FINISHED WITH NEW STICKERS)
205/40/16 BFG KDW'S 55% TREAD
BLOX FULL ONE PIECE COILOVERS
PROJECT KICS ANODIZED GREEN LUG NUTS
BRAKES:
BREMBO CROSS DRILLED AND SLOTTED ROTORS FRONT AND REAR
NEW GOLD CALIPERS FRONT AND REAR
GSR REAR DISC BRAKES
NEW BRAKE PADS FRONT AND REAR
CHASE BAYS BRAKE BOOSTER DELETE
BRAKE LINE TUCK WITH ALL STAINLESS STEEL BRAKE LINES
CAR ORIGINALLY HAD ABS BUT IS NOW GONE
ENGINE & ENGINE BAY:
WHOLE ENGINE BAY STRIPPED, PRIMED, PAINTED, AND CLEAR COATED TAN
FULL WIRE TUCK
BATTERY RELOCATED
FUSE BOX BEHIND PASSENGER KICK PANEL
K20A BLOCK
K20A2 TYPE S HEAD
ARP HEAD STUDS
OEM ACURA HEAD GASKET
DTR REPLICA 4-1 HEADER
BOLT BOYS FULL POLISHED ENGINE BOLT KIT ALMOST EVERY BOLT YOU SEE IS NEW AND POLISHED
FULLY POLISHED ONE OF A KIND RBC INTAKE MANIFOLD (SHAVED EVERY NUB OFF AND WELDED UP MAP SENSOR HOLES, ALSO CUT ALL WEBBING OUT)
BLOX THROTTLE BODY SPACER
STOCK TYPE S THROTTLE BODY
WHOLE MOTOR PAINTED MATTE BLACK
HYBRID RACING GREEN RADIATOR HOSES
HYBRID RACING GREEN BACK LOWER COOLING HOSES
HYBRID RACING BLACK FUEL RAIL WITH FULL FUEL LINE TUCK
HYBRID RACING EKK2 MOUNTS BLACK WITH GREEN INSERTS
HYBRID RACING BLACK CLUTCH LINE
CHASE BAYS ENGINE HARNESS WITH BLACK MIL-SPEC CONNECTOR AND FIREWALL PLATE
BLACK WORKS ALUMINUM RACING RADIATOR WITH SLIM FAN
POWDER COATED WHITE K24 VALVE COVER WITH K20A TYPE R BLACK DIP STICK
POWDER COATED WHITE EG SUBFRAME WITH NON POWER STEERING RACK-N-PINION
POWDER COATED WHITE MOUNT BRACKETS
POWDER COATED WHITE CUSTOM COLD AIR INTAKE TUBE WITH K&N FILTER
PRB HONDATA K-PRO
SPARKKS RACING K-SWAP CONVERSION HARNESS
EP3 IDLER PULLEY
TRANSMISSION:
04 ACURA RSX TYPE S K20A2 TRANSMISSION
NEW OEM ACURA 2ND GEAR
OEM SHIFTER CABLES AND SHIFTER BOX
K-TUNED SHIFTER BOX RELOCATER
COMPETETION STAGE 5, 6 PUCK UNSPRUNG CLUTCH
BOLT BOYS FULL POLISHED TRANSMISSION BOLT KIT
EP3 32MM AXLES
EXHAUST:
FULL 2 1/2 INCH PIPING
APEXI WORLD SPORT 2 MUFFLER
OVERALL THE CAR IS IN PRETTY GOOD SHAPE AND CONDITION, IT HAS TAKEN BEST ENGINE BAY IN A PORTLAND CARSHOW AS WELL AS BEST CIVIC, HASNT BEEN IN ANY OTHER SHOWS SINCE...
IT WAS DYNO TUNED AT SPEEDFACTORY AND PUT DOWN 223WHP
I HAVE OWNED THIS CAR FOR ABOUT 4 YEARS AND HAVE DONE PRETTY MUCH EVERYTHING ON THIS CAR MY SELF OR WITH THE HELP OF FRIENDS, IT HAS ITS OIL CHANGED EVERY 3000 MILES WITH MOBILE ONE FULL SYNTHETIC, AND ALL FLUIDS ARE CHANGED FREQUENTLY.
IM OPEN TO LOOK AT TRADES BUT ONLY SUBARU STI'S AND OR 06 AND UP WRX WAGONS OR 04 AND UP LEGACY WAGONS MUST BE MANUAL NO AUTOMATICS
PLEASE DONT CONTACT ME WITH STUPID OFFERS, IF U DONT HAVE THE ASKING PRICE OR A CAR THAT IS POSTED DO NOT CONTACT ME, I HAVE COUNTLESS HOURS AND TONS OF MONEY INTO THIS CAR AND I WOULD LIKE TO SEE IT GO TO A GOOD OWNER, IF I DONT GET ANY BUYERS I WILL GLADLY KEEP THE CAR..
IM ASKING $11,900 AND FIRM ON THAT UNLESS PARTS ARE TAKEN OFF TO LOWER THE PRICE
I AM PROLLY FORGETTING A **** TON OF STUFF, IF YOU HAVE ANY QUESTIONS AND OR ARE INTERESTED IN THE VEHICLE PLEASE CALL OR TEXT ME AT 206-947-4889
***********NO TEST DRIVES UNLESS I HAVE CASH IN HAND***********
NOW ONTO THE PICTURES AND YES THE CAR DOES HAVE A HOOD
EXTERIOR:
INTERIOR:
AUDIO:
BRAKES:
FULL WIRE TUCK
BATTERY RELOCATED
K20A BLOCK
K20A2 TYPE S HEAD
ARP HEAD STUDS
PRB HONDATA K-PRO
EP3 IDLER PULLEY
TRANSMISSION:
EP3 32MM AXLES
EXHAUST:
killakalipoph
Jun 20, 2012 01:24 AM
GLWS
