Darton Sleeved b18a1?? PICS!
Old Jan 28, 2012 | 10:25 PM
JDMCIVIC919's Avatar
Default Darton Sleeved b18a1?? PICS!
Some local guy is selling a darton sleeved b18a1 block. He says its the 300 series. Ive been looking up and reading on dartons website n other sites as well. Darton makes 2 types of sleeves dry n wet. This local guy is selling one and i dunno if its dry or wet. He is asking $500 for the bare block which is a good price. It is 81.5mm bore. Someone help me out about this block. Here is a link with pics of where its for sale. Look at the block n tell me what u think. Does the block have a block guard or is that with the sleeved block?
http://www.tamparacing.com/forums/ho...ngs-clips.html
Old Jan 28, 2012 | 10:27 PM
Default Re: Darton Sleeved b18a1?? PICS!
Is there a way to tell if anythign is messed up? how do i tell if its darton? Im meeting up with him by where he lives so i cant take the block n the seller to my machine shop to have my friend see if it was installed right, etc
Old Jan 28, 2012 | 10:28 PM
Spawne32's Avatar
it looks like dry sleeves and a block guard to be honest, imo that would be the reason its so cheap, assuming its sleeved at all
Old Jan 28, 2012 | 10:41 PM
Spawne32's Avatar
here we go, found a good comparison for you
http://hondamarketplace.com/showthread.php?t=2352535
Old Jan 29, 2012 | 07:15 AM
Yea thanks found out its dry sleeved. Like how do i know for sure its sleeved? Its a drive for me to go just look at it. In that pic does it look legit?
Old Jan 29, 2012 | 08:06 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It's a block gaurd - poorly installed at that. Only way to tell would be to measure the sleeve. It also depends on which sleeve they used... I would just forget about that and look for something else.
Old Jan 29, 2012 | 08:13 AM
U think it would be a bad buy? Im getting this block with bnib supertech 9.1 84mm pistons, eage h beam rods, mirco polished crank, arp headstuds, new oil pump, water pump. All for $1150 not a good buy?
Old Jan 29, 2012 | 08:55 AM
if i get this block im going to bore it out to 84mm to fit those pistons is that safe? too thin where it can crack? aiming for 400+
Old Jan 29, 2012 | 12:11 PM
blackeg's Avatar
yeah they look like factory sleeves to me. you can see where the iron sleeve insert its inside the aluminum casing on the factory ones. it appears as grey rings around the sliver on the top of the sleeves
Old Jan 29, 2012 | 12:52 PM
AllShowNoGo727's Avatar
cough up the money and buy a Real sleeved block, GE, Darton, LA, Benson or ERL, I had a block like that before and was unhappy with it. Went to real sleeves and never looked back.
Old Jan 29, 2012 | 12:55 PM
osc007's Avatar
^^^ +1.
I saw that deal and was about to jump on it and decided to just wait a couple of weeks and go with a brand new one. Not busting the guy, but as much money as i put in to my build thus far I rather KNOW what I have.
Old Jan 29, 2012 | 01:34 PM
So what u guys are saying that this block is not even darton dry sleeved? From the looks of it i thought it was. This car is just my daily driver and not a race car. Only aiming for like 400+. I just wanted a decent reliable block. I heard a lot of good things about the darton dry sleeves.
Old Jan 29, 2012 | 01:41 PM
Spawne32's Avatar
I wouldnt buy it for the sheer fact that it has a block guard installed, but its impossible to tell what sleeves it has from that retarded tiny pic he posted
Old Jan 29, 2012 | 01:50 PM
DO IT ON ALL FOURS
Stock sleeves will typically handle up to around 450whp reliably with a great tune. Sleeving a block is highly recommended either way. The integrity of the dry sleeves all lies in the install. As with everything bad install = problems. The deal you posted is decent, I will give you that, but it seems shady. Dry sleeves are the hardest thing to "do right" on these engines. (Wet sleeves aren't that big of a deal - it just requires the proper equipment to do so - which is $$$$$$$.)
Old Jan 29, 2012 | 01:54 PM
Would i be able to check if its done right? The block is bare but im getting all those parts with it and sending it out to the machine shop to get it bored n all that so he will tell me if something is wrong but i dont want that to happen. He seems legit and has a good rating on the local forums. Came out of a running car. Also would it be ok to bore this out at 84mm? Ive read up that it leave .083 wall left n thats enough to handle 500+ or should i just leave it at 81.5? Only reason i want to bore it out at 84mm cuz thats the pistons he is giving me.
TravisBiggie
Oct 18, 2013 05:08 AM
jimmy051702
Oct 16, 2011 09:37 PM
Boosted_EG8
May 9, 2009 12:12 PM
jdm00civicex
Texas -OK -LA (Sales)
Sep 26, 2008 12:40 PM
Twenty36_1
Aug 14, 2003 12:32 AM
