2000 Accord Surging
Old Jan 28, 2012 | 09:39 PM
Tester2k's Avatar
Default 2000 Accord Surging
I've got a 2000 accord 4cy auto and when the the ac/defroster is on the and the car is at a stop it surges what could be the cause of this
Old Jan 29, 2012 | 07:55 AM
Lost Again's Avatar
Default Re: 2000 Accord Surging
Alternator, ground. ECM/PCM, battery......the load of the defrost is causing the ECM/PCM to adjust. Now the question is what/which......several tests to get there.
Me, I'd start simple. Check the gounds to be sure they are clean and tight....and have the battery tested.
From here, you'll need a voltmeter, a good manual and some time.
johnrwinkorea
Jan 21, 2014 08:46 AM
52172
Apr 10, 2007 09:05 PM
Heinvenkin2
May 2, 2002 02:30 PM
