B20B thermostat
Old Jan 28, 2012 | 07:33 PM
jumpin4abeat's Avatar
Default B20B thermostat
The car stays cold unless I turn the temperature control to cold. If I turn the **** to hot the needle will drop all the way back to C. I have heat but its just a little warm. Sounds like the thermostat is bad? Stuck open? If I put the air to cold the needle comes up a little bit, maybe 1/4 way. Does it seem like a bad thermostat?
This may sound like a stupid question but in a B20B motor is the thermostat located in the top hose or the bottom? I have read about the B20Vtec motor has it on the bottom but nothing about the non-vtec motor. Also do I get a low temperature thermostat, like 170 or is the 180 or 195 just as good?
Old Jan 28, 2012 | 07:40 PM
94EG8's Avatar
Seagull Management
Default Re: B20B thermostat
Bottom, the same place every D and B thermostat is.
Old Jan 28, 2012 | 08:54 PM
NotAJDMFanBoy's Avatar
It's in the...thermostat housing, on the water pipe.
sickofitall1113
Feb 12, 2011 08:11 AM
danielblushtein
Jun 25, 2010 09:58 AM
JLUDE01
Nov 28, 2007 04:35 PM
sony224422
Jan 29, 2007 05:24 PM
Hondaciv95VX
20
Dec 5, 2005 01:41 PM
