2000 integra overheat sorta issue
Old Jan 28, 2012 | 05:08 PM
gsrhatch95's Avatar
Default 2000 integra overheat sorta issue
Weird things going on....
I have a 2000 Gsr integra stock motor but my radiator is a civic Fluidyne dual core with a stock fan attached
If im driving my car with the heat on my temp needle stays well below the middle of the indication....even if the heat is actualy off but my temp changing switch on the center console on heat it still says well below halfway mark on temp guage
as soon as you flick it over to cool for say the ac...the temp goes up to the halfway mark really quick and you can sorta smell a little antifreeze, not much at all but a little
Car idles kinda crazy sometimes too i know i have a small vacuum leak or something im going to get a vacuum guage tommorow and do the step in the helms manual
is this my head gasket?
Old Jan 28, 2012 | 05:13 PM
gsrhatch95's Avatar
Default Re: 2000 integra overheat sorta issue
read this could be the heater core also?
Old Jan 29, 2012 | 12:12 AM
01oemTeggy's Avatar
Sounds like a leak. Let your car sit while running to find any leaks on the ground. Or try getting the right radiator.
jesshaines
Jul 4, 2017 08:09 PM
KSavaiki224
10
Jun 16, 2015 10:33 AM
DWOL
Feb 9, 2009 07:32 PM
b18BoostedDC2
Feb 29, 2008 10:32 AM
parker14us2000
Sep 25, 2005 04:00 PM
