96-00 "headlight harness"
Old Jan 28, 2012 | 01:38 PM
SPOOLINmatt's Avatar
Default 96-00 "headlight harness"
anybody have any insight as to why this makes a full loop? Im redoing stuff on the race car and trying to reduce anything in the front that does very little. I want to basically cut off the harness right after the passenger lighting before it heads back to the plug on the passenger side. as far as i can tell the only wires i need from that pass plug side are for the fan. Maybe it makes a full loop because of ac controls coming from one direction and the headlight power coming from the other? I know the car will run without that harness regardless. My civic is a 99, i looked at my buddies 00 si and a friends 97 civic and both harness on the driver side have a blue connector with several pins and a gray connector with several pins. mine on the driver side just has a blue connector with several pins and a gray connector with just 2 pins? no other connector. Just seeking information to reduce all the crappy wiring harness.
Cap'N Chronic
13
Apr 26, 2011 10:26 AM
jasoncanseeoh
Feb 9, 2010 12:14 AM
BoostinEJ1
Jul 20, 2007 02:02 PM
jsnm
Jul 22, 2006 06:07 AM
_Spugen_
Jul 25, 2004 12:43 PM
