97 accord horn stuck on when headlights on
Old Jan 27, 2012 | 11:27 PM
Akebono's Avatar
Icon2 (solved) 97 accord horn stuck on when headlights on
97 accord dx
No aftermarket parts or alarms
+srs
Hello,
Horn works properly except stays on continuously when headlights are turned on. I am surprised that pulling the fuse for the horn does not stop the problem! I searched and couldn't find an answer to this one.
I have disconnected the horns so at least I can drive. Also tried disconnecting the battery for a while to no avail. Should I replace the headlight switch, the horn relay, or something else? I am puzzled why pulling the fuse doesn't kill it (yes it is the correct one, it is clearly labeled). Thanks for your help!
J
Addendum:
Problem solved. Wiring in right wheel well had dropped down (I can recall hitting a tire tread recently on that side) and was rubbing the wheel. Insulation was stripped causing a short between two wires. Electrical tape fixed the problem!
J
Old Jan 28, 2012 | 07:57 AM
Lost Again's Avatar
Default Re: 97 accord horn stuck on when headlights on
Does this dx have srs?
benfromthebay
Jan 15, 2017 08:32 PM
JDMCRX
Jul 16, 2012 07:38 PM
bizak
Dec 2, 2010 03:09 AM
goldiebio
Jun 19, 2005 08:21 AM
chronage
Sep 25, 2004 01:32 PM
