LS/Vtec Pistons
Old Jan 27, 2012 | 04:57 PM
donnie850's Avatar
Default LS/Vtec Pistons
What pistons should i use? b18a1 block, b18c1 head
Old Jan 27, 2012 | 05:10 PM
doood's Avatar
been there done that
Default Re: LS/Vtec Pistons
pr3
p30
p73
jdm p73 will give you the highest compression at around 12.5:1
Old Jan 27, 2012 | 05:19 PM
b20bFourDoorCivicLX's Avatar
hm cant wait i get my taxes in a week. i hope i can go lsvtec with out spending more then 2 g;s
i already have the b18a1 motor
Old Jan 27, 2012 | 05:23 PM
donnie850's Avatar
I hear ya.. I have the b18a1 motor also.. Got a sweet deal on a b18c1 head, already has the golden eagle ls/vtec kit. and a skunk2 intake. Just trying to figure out how much of a pain this will be to install and if i should change pistons. Im pretty new to this.
Old Jan 27, 2012 | 05:43 PM
if you dont mind me asking...how much was the deal?
Old Jan 27, 2012 | 05:48 PM
donnie850's Avatar
$450, i haven't bought it yet.
Old Jan 27, 2012 | 06:16 PM
DirtyDA9's Avatar
It better be in working order then but I still recommend getting new valves and having them and the seats machined, and i would go with pr3 or p30 pistons, depending on your goals.
To the other guy, you can definitely build an LSVTEC for under 2g's. I'm building a fully built LSVTEC and I'm not going to be spending anymore than 1500 tops, you just gotta look for deals on here
Old Jan 27, 2012 | 06:25 PM
mike703's Avatar
This is correct. im doing the same thing. personally im not a fan of the skunk2 on a gsr head but thats just me. if i were you i would put the p30s in so you dont regret not doing it down the road. right now i have 650 into my head. that included the head,bare gsr manifold,vtec solenoid, distributor,cam seal,valve cover,milled enough to clean it up, valve job, hot tank, and media blasted the old valves. i bought it all from craigslist. im also hoping to keep it under 2 grand but i want jun 3s so might not be possible. anyways get the p30s hands down.
Old Jan 27, 2012 | 06:37 PM
sebTeggy's Avatar
Originally Posted by doood
pr3
p30
p73
I don't think p73 will fit on an LS crank/rods. You will have to mill the rod about 1mm on each side. Get the p30s
The difference in compression ratio from p73 pistons (12.58) to jdm p30 pistons (12.52) is minimal. Get the p30s, they are cheap as ****
Old Jan 27, 2012 | 06:40 PM
yea im going to be doing the same thing hitting up craigslist and some friends, when i get done with my car ill post some pics
Old Jan 27, 2012 | 06:43 PM
osc007's Avatar
+1 on the p30's...
Old Jan 27, 2012 | 06:46 PM
mike703's Avatar
yes but where do you order your oem p30s from
Old Jan 27, 2012 | 06:51 PM
osc007's Avatar
here:
http://www.hmotorsonline.com/shop/sc...age&item=10015
nevermind... they are sold out...
Old Jan 27, 2012 | 06:57 PM
mike703's Avatar
yup i know and they never have them in 81.25
Old Jan 27, 2012 | 07:07 PM
doood's Avatar
just laying out the options
Old Jan 27, 2012 | 07:49 PM
mike703's Avatar
^^^^Exactly. and its not like a machine shop will have any difficulty performing the task for you.
Old Jan 27, 2012 | 08:04 PM
sebTeggy's Avatar
If you want to pay extra when you don't have to, be my guest.
Old Jan 27, 2012 | 08:31 PM
doood's Avatar
if you're already building the engine what's another couple dollars to have 1mm shaved off the ends?
Old Jan 27, 2012 | 09:38 PM
DirtyDA9's Avatar
I'm not a fan of skunk2 either lol.
Yea I spend a lot of time on here or craigslist looking for deals, I got my GSR head, complete with cams, intake manifold, tb, etc. Just had 2 bent valves, original price $250, but someone was going to buy it before me so I offered $300, still a deal.
And I just got new eagle rods with GE bearings for $150, now that's a straight steal.
Old Jan 28, 2012 | 01:48 AM
mike703's Avatar
^^^^wow that is a steal. my head came with b17 cams forget to add. ive always been a bit skeptic about ordering parts in the marketplace unless it was a sponsor or something ya know.
Old Jan 28, 2012 | 07:14 AM
DirtyDA9's Avatar
^^ Yea I kinda worry too, but I onl y really buy from people with like 2,000+ posts, and always check their other posts for a vouch thread. The post count doesn't really mean anything, but I still would never buy off someone with 5 posts lol.
Old Jan 29, 2012 | 11:39 AM
2000EKCoupe's Avatar
10 Year Member
you can get p30's from any honda dealer wit rings for about 200 bucks
Old Jan 29, 2012 | 05:50 PM
mike703's Avatar
^^^^^ thank you....and these are the part numbers 1310-P30-G00 standard
13020-P30-G00 oversized at majestic honda theyre about 50 buck per piston and i dont believe rings are included but im not sure.
Old Jan 29, 2012 | 05:59 PM
CUTTERSPOOL's Avatar
I would go with p30 pistons.
Old Jan 29, 2012 | 06:43 PM
10 Year Member
Yea majestic is the ****. Oversized pistons are same price too. Rings seperate tho. Still cheap and more reliable than aftermarket.
