Simple question, How do you test your driver side regulator motor?
Old Jan 27, 2012 | 04:30 PM
bsxiong's Avatar
Default Simple question, How do you test your driver side regulator motor?
I don't know if it's my master switch or my motor dying on me, but I want to connect the battery to the motor to test if the motor is still running.
Here is my problem: The connector's to the regulator have 4 pins. Which one does what?
Here is a look at it:
http://i.ebayimg.com/t/04725S00A01-N...n5g~~60_12.JPG
Can anyone help me?
Old Jan 27, 2012 | 07:33 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Default Re: Simple question, How do you test your driver side regulator motor?
Nobody knows what car you have .... but here's the diagram for a 5th Gen Civic:
Old Jan 27, 2012 | 07:48 PM
pancho y onions's Avatar
Couldnt of said it any better ^^
Old Jan 28, 2012 | 12:04 AM
ifIexplode's Avatar
First I would take the door panel off and see if there is power going going to the connector at the window motor. Get a volt meter. Hit the switch and see if youre getting 12v at the connector. The motor only has two wires. Power and ground.
To test the motor itself. Run power and ground wires directly from the battery to the motor connector. Switching the wires will just make the motor run in the other direction.
Psychoteen101
Honda Civic (2001 - 2005)
Dec 16, 2013 10:31 AM
Telecatster
Mar 16, 2013 07:32 AM
leopauvin
Jul 23, 2011 12:00 PM
bLaCkNbLueLuDe
Apr 28, 2009 04:40 PM
Uncle Willie
Jul 11, 2006 02:21 PM
