Extended top hat hood clearance
Old Jan 27, 2012 | 02:07 PM
bmxtrev's Avatar
Default Extended top hat hood clearance
Whats the most extension you can add to the factory top hats, and still be able to close the EF hood without any modification?
Old Jan 27, 2012 | 03:26 PM
crvtectim's Avatar
Default Re: Extended top hat hood clearance
6 foot 7 foot
Old Jan 27, 2012 | 04:49 PM
Cameron R's Avatar
I did 1.25" and I had to notch the hood, maybe 1" would work?
Old Jan 27, 2012 | 06:24 PM
bmxtrev's Avatar
Originally Posted by Cameron R
I did 1.25" and I had to notch the good, maybe 1" would work?
notch the hood as in cut through it? or 1.25 barely touched?
Old Jan 27, 2012 | 06:54 PM
Cameron R's Avatar
The threads on the top of the shocks rubbed on hood reinforcement. These were koni shocks and the top adjusters did not contact the hood skin. Extending 1.25" severely limits droop travel, so you need to go fairly low in ride height.
Old Jan 27, 2012 | 06:57 PM
bmxtrev's Avatar
i dont have adjustment ***** on the shafts, and yes, im dragging flaps in the front but shocks are compressed 1.5 inches farther than recommended.
so i should be good with 1.25"? i dont mind cutting away some hood reinforcement
Old Jan 27, 2012 | 07:28 PM
Cameron R's Avatar
By all means, go 1.25" and trim the hood reinforcement then, hood skin will be fine. However, going from 1.0 to 1.25 doesn't actually buy you anymore bump travel.
Old Jan 27, 2012 | 07:29 PM
bmxtrev's Avatar
are there any 1.25 inch top hats out there? the only ones i can find are 94mm or ~1 inch.
or will i just have to make my own?
Old Jan 27, 2012 | 09:57 PM
Stunna MIKE's Avatar
you could also space your hood up a bit and not have to cut away at the webbing.. check ebay.. im not sure of the size of the tophats.. but i know a couple people running them
Old Jan 28, 2012 | 10:34 PM
My_EFsedan's Avatar
im was on 1.5 and it doesnt hit with my tein basic. heres a 1.5 extended in my sedan for reference.
also really depends on what shocks your using. some shocks has longer threading on top
kyle92integ
May 28, 2005 01:34 PM
