1992 1.7 acura intera
i posted on the wrong form, i replace the oil senser light swicth,yesterday and the ligh still cam on , so i usind 5 30 casteroil, i put lucas oil treatment in it, i drop out an quart, i hope this work, can anyone hlp me, what engine rebuild? i just do not know i hope i can shave this engine, cause i broke and straned in Indianapolis, in, anyone
, YES< THE OIL LIGHT,Yes i did replace the sensor, new,but Hero ,i hope it not low oil pressure
(red)the light fikers, then gets solid color, then it goes away , took it out today , and light went away?? when i start the car, it now shows up, then dems, and goes out? so i did a 60 mile trip, and it went red, then dim, the out, well i am thinking,lol, since i have let it set for a 2 week period, that , it just oil and needs running, and i did the oil level is ok,after adding lucas oil treatment, going down the high way goes out , i listen to the engine and it sounds fine , but what do i know, yes i think i really sould pressure check it, but i have now way yet, thank you for responeding, i will let you know how the rest of the day goes, sincerly james white
you should be reading somewhere around 20-30psi at idle and around 80psi cruising.
if it's lower than that, i'd probably start by pulling the pan. have a look at the oil pick up and make sure it isn't clogged with debris. it's a good place to start, because next up is the oil pump, in which the pan needs to be removed anyways. if there is scarring on the pump housing, pump itself, or damage to the pump rotors, replace it. if not, there may be an issue with bearing clearances or clogged passages
