B20z2 stats
Old Jan 26, 2012 | 09:52 PM
theunknown's Avatar
Default B20z2 stats
Come to find out google doesn't have everything. I was looking to find some stats on my new car and couldn't find any.
Its a b20z2 with higher compression pistons, gsr vtec head, skunk 2 intake, and cold air intake. Also I have the s200 chip dyno tuned, on the last run the guy did he pulled 201 wrhp. Anyone can think of a track time it could pull??? Or even how fast the engine could go?
Old Jan 26, 2012 | 09:54 PM
Spawne32's Avatar
Default Re: B20z2 stats
the engine by itself would need to have wheels on it, but im not sure how fast it would go without the chassis, i would assume if you kept it in the car then you could probably do low 14's with no problem.
Old Jan 26, 2012 | 10:09 PM
theunknown's Avatar
But if I put a jet engine with it I would fly
Old Jan 26, 2012 | 10:18 PM
doood's Avatar
been there done that
maybe it'll blow up with you in it?
Old Jan 26, 2012 | 10:32 PM
theunknown's Avatar
Ill wear a nascar suit dont worry
Old Jan 26, 2012 | 11:15 PM
DirtyDA9's Avatar
I bet you your "high compression" b20z, doesn't have a knock sensor...
It's not high compression bruh.
Old Jan 26, 2012 | 11:18 PM
DirtyDA9's Avatar
I lol'd at the engine needing wheels.
Aparently his new car is a B20z2, that must be a new model... And he wants to know how fast his ENGINE can go? I lol'd again.
Old Jan 27, 2012 | 12:02 AM
theunknown's Avatar
Oh sorry for stating what the guy told me when I bought the car.
My bad bruhhhhhhh.
Old Jan 27, 2012 | 12:05 AM
theunknown's Avatar
And bruhhhh I said "higher compression" if you cant remember something thats right infront your face try and quote it next time.
Old Jan 27, 2012 | 11:29 AM
Gsrsi's Avatar
Is your name theunknown because you don't know any thing or because you bought something you know nothin about. Ls vtec.
Old Jan 27, 2012 | 11:45 AM
DirtyDA9's Avatar
Exactly, the guy lied to you, I'll bet money it's not a high compression B20. Bruhhhh
Old Jan 27, 2012 | 12:04 PM
B20ztek's Avatar
i see your also from lilweezyana, what part?
Old Jan 28, 2012 | 12:46 AM
el crapitan's Avatar
all b20z's came outfitted with the high compression phk pistons.
if it's a b20z stamped on the block, and has it's original pistons in tact, they're high comp.
Old Jan 28, 2012 | 07:04 AM
DirtyDA9's Avatar
only if it was a 99-00 with a knock sensor, no knock sensor, no high compression.
Atleast that's what I read in a b20 faq guide a while ago. I'm probably remembering wrong, but whatever.
Old Jan 28, 2012 | 07:08 AM
first sentence, 5th paragraph down
all b20z's are 99-00
Old Jan 28, 2012 | 07:20 AM
theunknown's Avatar
Yea he told me nothing about the car, point why I didn't say much.
Old Jan 28, 2012 | 07:22 AM
theunknown's Avatar
An hour from Houma, small town called Morgan City.
What part your from?
Old Jan 28, 2012 | 07:24 AM
theunknown's Avatar
I read a forum on the knock sensor, if you can find it or explain it I'll go look for it. Its stamped b20z2.
"The engine came out of a '99 Acura Integra with a gsr vtec head put on" So be said by the guy that sold me the car.
Old Jan 28, 2012 | 07:30 AM
don't worry about it. the concern of the high comp b20's is only for the jdm b20b's
Old Jan 28, 2012 | 07:38 AM
theunknown's Avatar
Ok. Me and B20ztek have basically the same build haha just my engine sat up for a year and it over heats, trying to figure that out now.
Old Jan 28, 2012 | 07:50 AM
does the fan kick on?
Old Jan 28, 2012 | 08:30 AM
theunknown's Avatar
I think I need another radiator, Ive never seen one like this the fans on the front side which would be pointless bc its blocking cold air while driving.
Old Jan 28, 2012 | 08:34 AM
theunknown's Avatar
Can you give me some reasons on why its overheating?
Theres steam that comes out the head cover breather. The oil isnt white so I cant understand whats wrong. The hg is good not messed up, the block isnt warped the head might be but monday ill be getting it shaved by a shop. We got the air bubbles out the radiator, changed the pump, the thermostat opens up so Im at a stand still now I hope its the head
Old Jan 28, 2012 | 09:23 AM
B20ztek's Avatar
Know exactly where that is. Im from New Orleans but yeah I live close to Alexandria
Goodluck, sounds my nissan 200sx i had, replaced every single component of the cooling system complete with new head and the bitch still overheated..
Old Jan 28, 2012 | 02:53 PM
theunknown's Avatar
Ever wanna make some money to do a rebuild? :D
I hope not, never found out the problem?
