B18c1 with full bolt ons only 145whp dynojet
Old Jan 26, 2012 | 05:43 PM
yutyut's Avatar
Default B18c1 with full bolt ons only 145whp dynojet
took my 1999 gsr to find out how much power i was really making. Its a stock b18c1 gsr with original tranny, 128xxx miles and the following mods:
-JDM type r ecu p73-003
-RSR ceramic coated headers
-skunk 2 intake manifold
-tanabe cat-back exhaust
-type r intake tube with k&n filter
-hondata gaskets
-type r throttle body
Ran it on a dynojet and did 3 pulls at 9k. Each time it was 145whp and 110tq.
I would've guessed at least 165 to the wheels. could the jdm ecu be the problem? maybe messing up the afr to where there is a dramatic loss in power? I have a usdm gsr ecu that i put in to pass inspections and it threw 02 sensor codes the other day. I replaced both the upstream and downstream sensors so idk if that might have something to do with it. any input would help.
Old Jan 26, 2012 | 05:45 PM
doood's Avatar
been there done that
Default Re: B18c1 with full bolt ons only 145whp dynojet
why are you running any ecu other than stock?
Old Jan 26, 2012 | 05:46 PM
yutyut's Avatar
ill upload a better quality picture later.
Gsrsi's Avatar
The skunk2 mani is killin your midrange.
yutyut's Avatar
it came with the car when i bought it.
Gsrsi's Avatar
X2
Also is it tuned?
Old Jan 26, 2012 | 05:52 PM
doood's Avatar
stock gsr's make ~140-150whp. with your gaggle of parts, im guessing no tune, and dependent on health of the engine, your numbers are about right.
Old Jan 26, 2012 | 05:58 PM
yutyut's Avatar
not tuned yet. i bought it a month ago as is to turbo it. im gonna be buying a p28 and running s300 very soon. im just surprised that it lost that much hp due to an ecu. Just goes to show how much of a noob i am. Can anyone tell me specifically why the power loss happened?
Old Jan 26, 2012 | 05:59 PM
yutyut's Avatar
ah good to go. ill have it tuned and post the improvements.
Old Jan 26, 2012 | 06:17 PM
GagnarTheUnruly's Avatar
Dyno's read vastly differently. I bet a "160" whp car could find a dyno where it read 145 and one where it read 185. That said I agree that your ECU is probably holding you back. I bet you're rich and that the timing is off.
Old Jan 26, 2012 | 09:03 PM
TOO MUCH TORQUE's Avatar
are those spark plugs necessary? oem sumitomos(spelling??) are the best plugs, better than NGK.
Old Jan 26, 2012 | 09:12 PM
doood's Avatar
ngk is oem. where did he mention spark plugs? i must've missed it.
Old Jan 26, 2012 | 09:17 PM
00_EKHatch's Avatar
lol, thinking the same thing here....
Anyways, my guess is the ecu, try to find either a stock one on the cheap, or upgrade to a chipped ecu like Hondata so you can really get the power down out of your mods with a solid tune. And to be honest, that intake is clean but if you want to squeeze the hp out of an all motor setup then you really need to get a real aftermarket cold air intake or short ram that utilized a well known filter. Built in velocity stacks are common these days in brand name filters and really do help.
Old Jan 26, 2012 | 09:59 PM
yutyut's Avatar
yea i know i need to upgrade the intake. i just ordered a chipped p28 from phearable.net with they're basemap. i'll eventually get s300 and have it fully tuned but hopefully ill see 165whp just from the ecu change.
Old Jan 26, 2012 | 10:04 PM
00_EKHatch's Avatar
Well, That IMO would be a HUGE gain from just swapping the ecu, but I hope it works for you man.
Old Jan 26, 2012 | 10:07 PM
yutyut's Avatar
your're right lol i guess i've had my head in the clouds a bit. but i would think a b18c1 with i/h/e and a basemap tune would see at least 160-165. we'll see next week when i take it back i suppose.
Old Jan 26, 2012 | 11:30 PM
DirtyDA9's Avatar
You are basing that off of stock numbers though, but your engine has miles, and wear and tear, after years of use your engine will not make factory hp.
Pluse your not tuned, if it were tuned you would have seen better results, and with the right ecu it would be better as well.
Old Jan 27, 2012 | 02:31 PM
Whiterice-gsr's Avatar
i tried every ecu that would plug into my gsr looking for a little extra and nothing performed as well as my stock p72, the only thing that will perform better is one dyno tuned to your ride and mods specifically
Old Jan 27, 2012 | 06:17 PM
mike703's Avatar
Am i the only one that noticed the title "with full boltons" and then looked at the shot of the bay and saw a stock intake set-up. i would say you could free up a decent amount up top if you get rid of some restrictions.
Old Jan 27, 2012 | 06:23 PM
sebTeggy's Avatar
What you mean lost? You never dynoed it before swapping ecus.
The reason is, you are running an ECU for a motor that is NOT A TYPE R MOTOR
Just because a type R has more horsepower, it doesn't mean that the type R ecu gives you more power
Get a tune. Your car is running rich probably
Old Jan 27, 2012 | 07:20 PM
osc007's Avatar
compression test? leak down test? is the motor healthy to begin with?
I would start here before I even look at any of the mods. but that's just me.
Old Jan 27, 2012 | 08:57 PM
raverx3m's Avatar
stock b18c1 >did 3 pulls at 9k
is like
stock LS motor> did 3 pulls at 10000 with b20 ECU still got no torque ... wtf.
gsr motor red line is 8100 and its there for a reason.
props on clean engine bay tho.
Old Jan 27, 2012 | 09:42 PM
DirtyDA9's Avatar
Could be an icebox setup. Nothing wrong with the stock intake, he's only losing out on 1-2hp.
Old Jan 28, 2012 | 01:50 AM
mike703's Avatar
^^^^true. i run a stock intake. and when i want it to whistle i take the top off. cant see spending hundreds on a shiny pipe with a subpar filter anyways.
Old Jan 28, 2012 | 07:22 AM
DirtyDA9's Avatar
^ ahah exactly, I'm rockin the stock rubber tubing with like maybe 1 foot of hard pipe and a filter attatched, but I'm really thinking about putting the stock box back on and making it an icebox setup, or just throwin a velocity stack on the stuck tubing haha ghetto, but it would work well.
What I really want is the "ricebox", All In Fab custome makes it, but the air box looks like a big box of rice haha
Tell me this aint ballin-
