Random parts from d to k
doing a basement/garage clean out...
i have a TON of stuff and it all has to go
READ!!!---some parts will have prices some wont all parts are OBO
located in baltimore md 21222
pick up locally preferred only because alot of parts are really cheap and
it would be pointless to drive and use gas for a part im only getting a few dollars for
can provide pics of invidual parts upon request
too many parts to take a picture of each
IF it is still on this list its still for sale so please dont ask if i still have it
call/text/voicemail/PM if i dont answer please leave message name/number and parts interested
Paris 410-292-5713
PLEASE READ ENTIRE LIST IN NO WAY IS IT CATEGORIZED
For sale:
- k series custom header used in 92-95 civic with k24 custom made by Matt butram 1 7/8 runners to a 4-1 outlet has flowmaster 4-1 3in outlet race header
- bseries aluminum after market fuel rail no name polished look
- driver side 92-95 civc manual mirror black has small crack on outside
- rear defrost switch 92-95 civic and other misc switches out of dash
- engine bay fuse box 92-95 bare
- k series oem injectors 310 cc 3 sets
- b/d series oem injectors 1 set
- kseries map sensors x3
- d16z6 valve cover will work with any dvtec head x3
- d16z6 oil pan should work with any dseries block
- d16z6 head complete no dizzy
- d16z6 vtec solenoids x2
- d16z6 misc hoses
- d16z6 throttle bodies no map sensors x2
- d16z6 iacv
- d16z6 pcv boxes x2
- k24 intake manifold cover x2 1 silver 1 black
- k20 intake manifold cover x2
- k24 spark plug cover
- k20 spark plug cover
- obd0 bseries dizzy with msd ext coil cap
- steel braided oil line -3 or -4 fittings on each end
- a bunch of misc steel braided lines diff sizes and lengths
- steel braided line with push lock fittings
- oil feed line steel braided w fittings
- nitrous express fuel solenoid w lines and adapters
- oil return line w turbo flange that bolts to turbo and other end is cut
- k series shifting mechanism that bolts to trans
- oem civic/integra CAT converter
- 92-95 ex cluster goes to 9k
- k20a2 water pump
- 94-01 integra rear seats only bottomns
- d16z6 stock cam x2
- k series shift forks
- Dseries trans s40 complete still together
- kseries water turbing and thermostat housing
- k20a2 water pump x2
- k20a2 crank pulley
- k series timing chain guide and oil pump change guide
- k series intake cam gear PND
- k24 valves
- k series belt tensioner
- 3" in high flow CAT converter
- 2 obdo pr4 ecus
- 2 b2o/ls valve covers
- d16z6 block pretty bare have some stuff
- k24 oem fuel rail
- k24 coil packs
- intercooler piping 92-95 civic pretty sure i have complete piping also has synapse BOV
- k series swap t bracket for rear mount brand new
- obd0 pm6 ecu chipped
- B series turbo manifold greddy
- greddy turbo downpipe
- k series shifter cable bracket for trans
- 92-95 stock fuel pump hanger
- inline fuel pump not sure brand good for 600hp has fittings on each end
- Spearco frount mount not sure of dimensions i can get them
- k20 flywheel
- k24 flywheel
- k series speed sensor k20a2
- k series shifter box
i know its a long list please read all
any questions comments concerns or interest feel free to ask
thanks for looking!!!!
Paris 410-292-5713
For sale:
- d16z6 misc hoses
- d16z6 iacv
- k20a2 water pump
- k24 valves
- 2 obdo pr4 ecus
- k24 oem fuel rail
- k24 coil packs
- k20 flywheel
- k24 flywheel
SMSP
Nov 29, 2003 04:00 AM
