Whats for dinner?! Build thread
Old Jan 26, 2012 | 12:15 PM
Rice For Dinner's Avatar
Default Whats for dinner?! Build thread
so i picked this 90 Si with an LS swap up awhile ago. i bought it not running, but all the work i put into it, i finally got it running as of yesterday
Size:  121.3 KB Name:  197.jpg
Old Jan 26, 2012 | 12:20 PM
crvtectim's Avatar
Default Re: Whats for dinner?! Build thread
I'm diggin' the pink bay. :p
Old Jan 26, 2012 | 12:26 PM
over the past couple of months ive been picking up random parts. For right now, im gonna be running a NA LS motor. with just i/h/e setup. when it gets warmer im going to restore and paint it.
Size:  126.2 KBName:  003.jpg
Size:  44.8 KBName:  004.jpg
Size:  55.8 KBName:  IMG_0301.jpg
Size:  31.2 KBName:  IMG_0440.jpg
Old Jan 26, 2012 | 12:27 PM
im not feelin' it haha
Old Jan 26, 2012 | 12:41 PM
so i got it running yesterday, and it fired up fine. the rpm gauge wasnt working yesterday but it was idling at around 2500-3000rpm constant. i let it sit for awhile and keep turning it off and on. i hear a hissing noise which im assuming is a vacuum leak. and today the rpm guage decided it wanted to work. i seen it was idling at 2500 and would drop and go back up and drop down again. i tested the clutch moved it back in forth in my drive way. it got stuck in gear. and finally i got it out to move it back and i hold the clutch all the way to the floor and try to put it in reverse and it grinds and wont go in. i started it again today while it was in gear and when it started the shifter was wobbling really bad. and now when i try give it some gas it just dies down. and if i keep the pedal down it just dies. as for my fuel setup. im running an AEM rail, stock regulator, stock injectors which i believe are 240cc?, i replace the fuel fliter, and the pump is working fine. i was told i need to check my timing. i check to see if i flooded the engine but the spark plug tip was dry.
Old Jan 26, 2012 | 12:54 PM
as for my build. ive started my wire tuck about 45% done, all i have to do is extend wires on both sides. but the fusebox is mounted in place. the wiring harness i picked up form crx_si-r i had to wire a coulple more things myself. but instead of splicing them, i just put them in a connector. i converted the car to OBD1 also, if you need an ecu and dizzy jumper i have them!
Size:  107.5 KBName:  IMG_0349.jpg
Size:  118.2 KBName:  IMG_0447.jpg
Old Jan 26, 2012 | 04:20 PM
crvtectim's Avatar
Sounds like you need to adjust your clutch cable.
b18bcivic
Sep 23, 2004 10:22 PM
weakGOODJunKieS.com
Jul 8, 2002 07:55 PM
