99 Accord auto Trans issue
99 accord, over 255k miles, 4 cylinder,
My issue is if i drive super slow the trans mission does not want to shift to higher gears. If I accelerate very slowly the car will rev up to 2.2-2.5k rpm before shifting. Almost like it is hesitating to shift. It never shifts before 2k rpm like most automatic cars if accelerating slow.
I have not changed fluid. Do you guys think it is the fluid?
Main idea: the car doesnt shift at low rpms like most automatics even at 5% trottle.
---Any tips would be helpful. Any sensors that could be effecting it?
---It trows no check engine code.
make sure if you change the fluid to only use honda atf from the dealership. i believe you also have to have the car hot and on level ground to get a correct reading on the dipstick.
your tranny is slipping. these transmissions are notorious for dying on us. my gfs did the same thing 3 months back. she has on 02
Slipping? yeah i know who the guy who had the car before me and pretty sure its the tranny fluid. When i changed the oil he had some weird brand oil filter on it. so he prob used some lame fluid.
Thanks for you help... I dont need this trans slipping on me..
5.4ever
11
Feb 3, 2014 03:30 AM
1996accordlx22
Aug 5, 2012 07:30 AM
