just bought a 95 oddy. what coil over or springs are best?
ok so i just purchased an oddy and want to give it a drop.What spring or coil overs do i use cus i have not a clue.Do u use accords? Lil help please I'm a noob to oddy's. thank guys
http://www.odyclub.com/forums/28-199...16-12-now.html
Check this out. Tein Lowering Spring on Group Buy discount!
Tein makes springs, but the drop is very mild and the springs are pretty soft.
If you want a decent drop a set of coilovers is your best bet. Every now and again a set of coilovers will pop up from over seas, usually in the $800-1000 range.
Also, since the front is identical to the accord, some guys use accord coilovers in the front and then trim the factory rear springs. They seem to have decent luck with this set up.
