1999 EK9 HB**MILANO RED**JDM**CLEAN**SF
Old Jan 25, 2012 | 05:59 PM
RZbltCRX's Avatar
Default 1999 EK9 HB**MILANO RED**JDM**CLEAN**SF
Hello HT!!I'm selling a 1999 Honda Civic HB DX, clean title, non-daily driven, mildly modified, no leaks, not really needing a 2nd car at the moment and reasonable offers will be considered, thanks for checking out the post!!
Please PM with any questions you may have for the vehicle.......NOT WILLING TO PART OUT AT THE MOMENT**NO TRADES PLEASE**CURRENTLY REGISTERED & SMOGGED
**This setup has never been TRACKED, RACED or ABUSED**
**asking $7k or best offer(reasonable ofcourse)**
Exterior:
-R81 milano red paint (approx 5 months old)
-CTR front & rear lip
-SI grill
-OEM headlights
-JDM thin side moldings
-CTR wing w/adjustable brackets
-Inline Four side mirrors
-OEM new belt moldings
-JDM window visors
-JDM antenna block off plate(not installed) but included
-6k HID's
-CTR fenders w/sidemarkers w/ JHP usa plug & play sidemarker harness
-OEM front mudguards only
Interior:
-GSR front seats (light grey to match) slight tear on left lumbar, 1999 SI armrest, 1999 SI cluster that reads 130k, otherwise all stock interior
Engine:
-STOCK engine D16y7 with approx 110k but cluster reads 141k(changed to 99 SI cluster), all maintenance done according to mileage required, NEVER SWAPPED!!!
-aftermarket piping from catback finished off with a CTR muffler, muffler ONLY!!
Chassis:
-weapon R sleeve coilovers( gotta roll on something!!)
-tokiko blue shocks
-1999 civic SI front lower LCA's & forks
-ITR 5 lug conversion, BLOX xtended lug studs, RCREW solid spherical bearings(trailing arm bushings), exedium rear camber kit, skunk 2 front camber kit, CTR front & rear sway bar, OEM 1999 SI front endlinks, BLOX rear endlinks, ASR subframe brace(silver color), BLOX rear LCA's w/new bushings(silver). new front/rear pads OEM, new OEM front rotors, resurfaced rear rotors, replaced right rear bearing OEM, BLOX open ended xtended lug nuts(red), OEM new ITR master cylinder, CTR proportioning valve, new E-brake cables 1999 SI, last but not lease JDM 98 SPEC ITR 16's gunmetal w/H centercaps newly powdercoated, wrapped with DUNLOP direzza's 215/45R16, less than 100 miles on them, full treadlife remaining.
**That should be it, this car is ready for track or for show you decide, if theres any questions about the car whatsoever ill be more than happy to answer them for you, thanks again**
Old Jan 25, 2012 | 06:05 PM
L0WL1FE's Avatar
Default Re: 1999 EK9 HB**MILANO RED**JDM**CLEAN**SF
Bump!! seen this on craigslist clean as f***
Old Jan 25, 2012 | 08:33 PM
crazyskater510's Avatar
Old Jan 27, 2012 | 02:49 PM
EVOR_DC4's Avatar
this thing is pretty clean. glws.
Old Jan 29, 2012 | 10:01 AM
Integra Type-GSR's Avatar
Ttt
z06eateR
Nov 5, 2012 11:25 AM
MiNDTRiP03
Texas -OK -LA (Sales)
Jul 8, 2012 11:03 AM
RZbltCRX
May 17, 2012 11:58 PM
gtz
Oct 28, 2011 05:14 PM
sikvic00
Sep 14, 2011 07:18 AM
