MAIN SHAFT SENSOR QUESTION
Old Jan 25, 2012 | 03:16 PM
leothlyn's Avatar
Default MAIN SHAFT SENSOR QUESTION
Just pulled My bad AT trans. out of My 96 accord lx. It would only go in reverse & was whineing In all other gears.I flushed all the fluids & replaced the vss after pulling a PO715, but it didnt help. So I went to pic n pull & found one (97 lx) that I hope is still good. Anyways My question is this- does anyone know if the
main shaft sensor & the countershaft sensor are the same as each other?? Reason I ask is that I removed them both from the new trans before I actually pulled it from the car it was in, so they wouldnt get damaged. Makes sense,right
Well now I cant tell which is which . They look exactly the same & the numbers on one of them are to faded to read. I know that I should just buy two new ones, but Iam strapped & I got to get this done asap. Iam assuming they are both the same but if anyone knows for sure or different please let Me know
thanks-Dave
Old Jan 25, 2012 | 06:15 PM
leothlyn's Avatar
Default Re: MAIN SHAFT SENSOR QUESTION
nevermind, I just found out they are different. Does anybody know if their is a way to put power to these little dicks & test them?? I just checked ebay & they go for over a hundred a peice,.!BOGUS!!!
Old Jan 25, 2012 | 11:02 PM
MAD_MIKE's Avatar
MM Gruppe B
You don't put power to them, they are hall effects sensors. They will create a voltage output. You can check the resistance of the sensors to see if they are in spec, I think ~500Ω.
Make sure to clean off any debris and junk stuck to the magnet, and never reinstall them with the old O rings, you will need two 91309-PX4-003 O-RING (16X2.1) $1.88.
As for identifying which is which IIRC the clocking of the bolt hole is different. I think the front sensors bolt is at the 6 O'clock position and the rear one is at the 12 O'clock position. You can check this by placing the pigtails in the 12 O'clock position. For more H4A tech check out the link in my sig.
Ody tour
Transmission & Drivetrain
35
Oct 19, 2018 02:49 AM
2009HondaAccord
Mar 13, 2018 10:01 PM
auzzie1998
Dec 30, 2017 06:42 PM
