UEGO install S300- what settings need changed?
Old Jan 25, 2012 | 02:22 PM
hon2984's Avatar
Default UEGO install S300- what settings need changed?
whats up guys....I have had my UEGO in my car for a short while now, I have no other 02 sensor. UEGO is wired to the ELD, the voltage off set has been adjusted. The car was street tuned and all my A/F ratios were good, 12.8 @ WOT, 13.0 @ patial throttle, and 14.7 at low load conditions. O2 heater is disabled.
I have noticed some differences when using the wideband for closed loop operation, the A/F will cycle like a narrowband gauge from about 13.0-16.0 when driving in a low load situation, noticed mostly on the highway. When I uncheck the box to use the wideband for closed loop, i get a CEL for the O2 sensor (after a drive cycle), but the gauge does not cycle back and forth, the A/F will act normal while driving. Is there something else that needs to be changed in Smanager?
Old Jan 29, 2012 | 09:32 AM
hon2984's Avatar
Default Re: UEGO install S300- what settings need changed?
Spunkster on hondata's forum suggested adjusting the "Rate of change" in Smanager.
Has anyone else had to adjust these settings?
GSROWNSU
Apr 17, 2007 06:11 PM
Tad
Mar 7, 2005 10:53 PM
LudeyKrus
May 17, 2003 05:34 AM
HX_Guy
Aug 30, 2001 07:31 AM
