Fuel Overflowing
Old Jan 25, 2012 | 11:15 AM
str8edgexx's Avatar
Default Fuel Overflowing
I recently changed out all of my hard lines under the car on my '95 LS (rear brakes and the three fuel lines). Ever since I did it, when I fill up at the gas station, the pump does not automatically shut off and it overflows. I've combatted this by guesstimating how much gas I used and putting that much back in, but I would like to solve the problem. Is it something with the vapor line that could be causing this? I don't have any leaks anywhere in the system.
Old Jan 27, 2012 | 04:19 PM
str8edgexx's Avatar
Default Re: Fuel Overflowing
Anyone?
Old Jan 27, 2012 | 04:32 PM
TheRealTegger's Avatar
You must have dropped the tank to do all this. When you re-installed it, did you correctly reconnect the skinny line that runs alongside the big gas-filler tube? Are you sure the skinny line is not somehow blocked?
Old Jan 28, 2012 | 02:08 PM
str8edgexx's Avatar
yeah, I did drop the tank. I'll have to double check that skinny line I guess. Unfortunately I'll probably have to drop the tank again to do it, but its not as scary of a prospect as I thought it was.
tolowhb
16
Jul 24, 2020 07:37 AM
nick77538
Motorcycles
Jul 7, 2017 08:59 AM
vulch
May 8, 2015 08:09 AM
Chris Reynolds
Apr 24, 2015 02:21 PM
Acidcrakker
Nov 12, 2007 06:50 PM
