2000 Honda Accord Tranny
Old Jan 25, 2012 | 08:22 AM
Tester2k's Avatar
Default 2000 Honda Accord Tranny
Hi, Guys I ve got a 2000 accord with 237000 miles and have some slipage in between lower gears and when its cold i can start off from a stop and go to the end of the road and when it downshifts to stop it doesn't go to first gear. I have to put it in park and then cut the car off and back on to get it to go to 1st.only when it is cold. I was wondering if there were any senors that might need to be replaced or and addivtive that can be added to help it shifting
Old Jan 25, 2012 | 09:51 AM
Hairnandez's Avatar
Default Re: 2000 Honda Accord Tranny
sounds like an automatic since you didn't tell us what it is. its cheap and easy to drain and refill the ATF fluid. use Honda fluid not cheap shitty stuff for starters.
Old Jan 25, 2012 | 03:52 PM
Tester2k's Avatar
Yeah its an auto trans and the honda tranny fluid worth the price vs an other on the market?
Old Jan 25, 2012 | 05:20 PM
Hairnandez's Avatar
no, its worth every dollar. Please don't use generic brands.
Old Jan 26, 2012 | 12:22 PM
WHEEELMAN's Avatar
If it's a V6 model, there are 2 transmission fluid pressure switches. Changing those might help. Be sure to get the rubber o-rings for them also.
Drain and fill the transmission fluid, regardless of color.
Bout all you can do on those V6 4 speed auto's. However, if your mechanically inclined you could also tear it down and clean out the pick up tubes. Clutch pack material floats around and collects in them. There is an internal filter also, but you gotta tear down the tranny to get to it.
hondalover209
Jan 9, 2016 03:56 PM
Bill Goodwin
Transmission & Drivetrain
Nov 24, 2012 07:01 PM
licks
May 9, 2010 04:24 PM
DIABOLIC8
Jun 11, 2009 01:59 PM
slypest
Feb 21, 2005 12:30 PM
