Is this how honda-techians are height adjusting their Tein Flex's?
https://sites.google.com/site/redcap...lex-adjustment
Been in and out of forums and there is SO much different information.
Thanks
Thanks
Since I am adjusting the coilover by the shock body, I loosen the lower collar, and raise it to my masking tape marker. I can then grasp the shock (anywhere above the green cylinder is fine) and twist to the desired ride height. Once complete, retighten the lower collar, and nut at the top of the shock.
He explains how to do it here.
No
No
Now I know you're on drugs. Why are they NOT coilovers? They are a coil over your shocks. Even a stock setup is a coilover setup.
Let him talk. He keeps showing everyone that he has no clue as to what he's saying or doing to his car. Quite frankly with the stuff I'm learning I'm thinking he has some sort of learning disability.
No
No
It's a coil over over shock. That's what they ALL are. How does that not make it a "true" coilover? I'm just saying.
The car came from Honda with "true coilovers''.
We can get back on topic when you stop thread jacking every thread with your bullshit information.
Your turning the shock body itself.
if you're worried about this, you can unbolt the lower mount, raise the collar of the coilover, and spin the lower mount up. This would eliminate spinning the shock, but you'll have to unbolt the coilovers from the car. This will get anoying.
For Type Flex, only adjust the lower nut and turn the whole shocks to the desired height. The top nut only for spring preload adjustment.
nikech1
Oct 16, 2004 07:30 PM
underrated99si
Apr 22, 2003 04:27 AM
