questions "coupe VS wagon"
not aquestion but verify my assumtion that the master cylinder on the wagon is better that the one on my coupe
question 1. is the sway bars on the wagon thicker than the ones on my coupe?
question2 . if it is thicker cool, will it fit?
question 3. for some reason is the power steering pump on the wagon better than the one on my coupe?
question 4. is than an oem option for upgrading my power steering pump?
even easier is look at the part numbers...
when i owned a 92 lx wagon the master cylinder was the same as the lx sedan/coupe. according to http://www.hondapartsnow.com/genuine...0-SM4-A04.html the dx/lx master cylinder is the same for ALL accords from 90-97.
the sway bar is the exact same for ALL ex accords from 90-97 as well as all wagons.
power steering pump is the same
what kind of upgrade are you wanting? if you do more pressure you need a new rack designed for that. i am not sure you really want more power steering assist unless you have a physical disability to contend with
as you would want braking easier and do so with a brake upgrade
somewhat in a way like bisi did
using an S2000 oem water pump gear if i remember correctly
in a high power build of a F22A
2.4
HPL 15.4
TPL99.4
Castrol Syntec TopShop Challenge
coupedragracing
Jul 4, 2012 03:09 PM
Wilka
10
Jan 13, 2012 04:19 AM
B16Civic93
Jun 27, 2005 03:31 PM
