Slight popping coming from steering system when parked.
Old Jan 24, 2012 | 07:37 PM
Cap'N Chronic's Avatar
Default Slight popping coming from steering system when parked.
I'm not exactly sure what to make of this. Car is a 98 Civic EX with a B18B1 swap. No power steering.
When the car is parked, I can move the steering wheel a couple inches in each direction and it makes a popping noise? It has a little bit of play when the front tires aren't moving. It turns fine and everything as far as I can tell when I'm driving. Steering wheel occasionally shakes at higher speeds, but nothing crazy. I'm thinking the rack and pinion could be loose or going out. Anyone have any input?
Old Jan 24, 2012 | 11:20 PM
First.EG's Avatar
Default Re: Slight popping coming from steering system when parked.
sounds like bad tie rod ends to me
Old Jan 25, 2012 | 06:24 AM
I replaced the outer tie rods when I got the car, have less then 5k on them. How can I go about checking the inner ones?
Old Jan 25, 2012 | 01:33 PM
First.EG's Avatar
jack the front of the car up and shake the tire left to right and up and down. if you have play form side to side it will be the inner tie rods. if you have play up and down it will be the upper or lower ball joint.
buzkilr
May 26, 2011 12:21 PM
j0keefe21
Feb 5, 2009 04:25 PM
PatrickGSR94
Jun 18, 2007 12:32 PM
jabroni95gsr
Feb 13, 2003 04:12 AM
