Engine noise increase when warmed up
Old Jan 24, 2012 | 03:36 AM
alperx's Avatar
Default Engine noise increase when warmed up
Hi
When engine warms up, the engine noise increases very much compared to it's cold and just started.
why is it like that ?
Car is integra (LS/VTEC)
with forged pistons & rods.
oil is : castrol full synth 5w-40
Old Jan 24, 2012 | 03:48 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Engine noise increase when warmed up
What noise? Can you be more vague please?
Old Jan 24, 2012 | 03:50 AM
94B18EG's Avatar
Don't know what your noise is but maybe try running a thicker oil for starters
Old Jan 24, 2012 | 03:53 AM
alperx's Avatar
noise like coming from the cylinder head..
grinding.
Old Jan 24, 2012 | 03:57 AM
alperx's Avatar
maybe I can take a video of both cold and warm..
I'll try that.
Old Jan 24, 2012 | 07:13 AM
alperx's Avatar
ok, the thing is, it's impossible to understand the noise levels from the videos I took inside the car because the sound of video is too bassy, and I can't be outside as it's already raining.
What I realized is, the engine sound tone is just the same, but it's only much louder.
The noise level increase when hitting higher RPMs. Especially when VTEC engages, it's even louder.
The oil pressure is around 15 psi at idle when warmed up.
When it's around 25 psi before totally warmed up, the engine sounds much more healthy.
Maybe you can give an idea of what stuff I should consider checking.
Thanks..
Old Jan 24, 2012 | 07:32 AM
The Grumpiest
Absolutely not. You have not even told us where the noise is coming from. Head? Block? Transmission? Near the belts? C'mon. All you keep saying is that it get's louder when warm and that it's a grinding noise.
Old Jan 24, 2012 | 07:49 AM
alperx's Avatar
ok, I'm %90 sure that the sound is coming from cylinder head.
sorry for the question, maybe it sounds like a bit stupid, but I can explain this much..
Old Jan 24, 2012 | 08:11 AM
94B18EG's Avatar
Maybe try runnIng a heavier weight oil bc you could have pressure in your bottom end but with such a thin oil and being a lsvtec you could be loosing oil pressure in the head in term causing grinding noises....just a shot from the hip with the minimal information you have provided
Old Jan 24, 2012 | 08:27 AM
alperx's Avatar
is there any way to check the oil pressure at the head ?
Old Feb 9, 2012 | 08:52 PM
94blur's Avatar
That may be tough to do. Trying thicker oil is prolly the easiest, or u can pull off the valve cover and check if you have any clear signs of damage/noise. Possible valve clearance issue.
Danjal
Nov 27, 2008 11:51 AM
battosai
Mar 29, 2008 11:32 AM
Roostalee
Jul 29, 2007 06:33 PM
obsidianG35
Sep 4, 2003 08:55 AM
