Type R suspension upgrade
Old Oct 8, 2002 | 09:34 PM
Tomcat's Avatar
Default Type R suspension upgrade
I am planning a suspension upgrade on my 98 Type R. I am going to choose one of the following three suspension systems: Mugen Low Down Sports, Comptech/Koni Pro, TEIN Flex or HA. My car is a daily driver, but is used for occasional Autocross and is being setup for Solo I. If anyone has experience with one of these suspension systems please share your opinion.
Thanks,
Tom
Old Oct 8, 2002 | 10:10 PM
spoon_ek9's Avatar
Default Re: Type R suspension upgrade (Tomcat)
forget about HA, get flex.
Old Oct 8, 2002 | 10:13 PM
hooptie157's Avatar
Default Re: Type R suspension upgrade (spoon_ek9)
Mugen Low-downs are a great choice for a weekend racer. No crazy adjustments. Only a select few can actually take advantage of a Full coil over setup. I'd either go with the lowdowns or a kg/mm/spoon spring setup w/ some koni's
Old Oct 8, 2002 | 10:16 PM
disordeR's Avatar
i would suggest.. the lowdown or zeal b2 suspension.
Mike @ IPS has them B2 suspensions on sale for a really good price.
http://www.ipsracing.com
Old Oct 8, 2002 | 10:33 PM
98itR484's Avatar
Default Re: Type R suspension upgrade (disordeR)
I got the HA's..well now flex...i love them, very comfortable ride when set at soft, and is awsome when stiff. im please with what I got for what I paid
Old Oct 8, 2002 | 10:42 PM
Reid's Avatar
Global Moderator
If you're setting your car up for Solo I you might want to call up Truechoice and have them set you up with something.
Old Oct 8, 2002 | 10:53 PM
superguy's Avatar
Default Re: Type R suspension upgrade (Reid)
Old Oct 9, 2002 | 12:11 AM
AJ PwR's Avatar
Spoon dampers very streetable and more than enough for lapping days.
Zeal B2 very good for street.
Old Oct 9, 2002 | 12:15 AM
itr-j's Avatar
Default Re: Type R suspension upgrade (AJ PwR)
cut u're springs is the nice and free way
Old Oct 9, 2002 | 12:16 AM
Unlimited's Avatar
New User
Default Re: Type R suspension upgrade (itr-j)
buy the spoon dampers from pat good deal 2g's cdn i think
Old Oct 9, 2002 | 01:20 AM
RagingAngel's Avatar
Default Re: Type R suspension upgrade (Unlimited)
Thanks for the honorable mention Unlimited.....
There is a buyer pending if anybody can vouch for me here!
Old Oct 9, 2002 | 01:59 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Have you looked into Zeal B6's? Mugen seems to be a pretty safe bet for street/autox if you really need the comfort on the street.
< who can't wait till he can say screw comfort and strap on a set of Buddy Club or S6's with some hella stiff spring rates.
Old Oct 9, 2002 | 06:05 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Type R suspension upgrade (Active (ActiveAero))
I've driven on the Mugen Lowdown. Its setting is more than enough for occasional track driving. I highly recommend it.
Old Oct 9, 2002 | 07:44 AM
Todd00's Avatar
I said I don't want a title!
For now, get some Konis and a GC coilover kit with reasonable rates. Then if you ever want to get "serious", you can get the Konis revalved/shortened and get some better springrates.
B2, mugen lowdown, etc are ok for the street, but they are a far cry from a true race suspension.
Old Oct 9, 2002 | 07:55 AM
BlueR's Avatar
Default Re: Type R suspension upgrade (Todd00)
i can't decide between the lowdowns or the b6
both about the same price...
Old Oct 9, 2002 | 09:00 AM
Todd00's Avatar
Default Re: Type R suspension upgrade (BlueR)
B6 without a doubt if you are looking for more of a race suspension. The lowdowns have 0 adjustability...the B6 you can adjust everything on.
If you just want a street suspension, then go with the lowdowns.
Old Oct 9, 2002 | 10:44 AM
ak-s2000's Avatar
I went with the lowdowns. Like the Koni yellow it has 5 setting for the dampener. Also, added the Mugen rear 26mm bar. The only reason to get a coil over suspension is to corner weight the car, otherwise it serves no other advantage. The Mugen setup is straight forward and direct bolt in, no mods what-so-ever. The ride is great and I would have it no other way. It only drops the car 3/4" so it will not need a camber kit. Actually, it gives the car a little more neg. camber which is nicer but not enough to induce excessive tire wear.
Old Oct 9, 2002 | 10:57 AM
disordeR's Avatar
Default Re: Type R suspension upgrade (ITR_00-0207)
The only reason to get a coil over suspension is to corner weight the car, otherwise it serves no other advantage. .
you lose 3 way adjustability with the lowdowns.
Old Oct 9, 2002 | 11:00 AM
BlueR's Avatar
if only the lowdowns didn't cost as much as the full coilovers...
then my decision wouldn't be so hard
Old Oct 9, 2002 | 11:33 AM
Kengs's Avatar
Actually, the main advantage with true coilovers is the ability to run very high spring rates without the need to re-valve. Zeal S6 can run 16-18kg/mm out of the box, you can't do that with ordinary shocks and sleeved coilovers. Whether you or not you need to run those kind of spring rates is the question
Another by-product of the superior damping performance of true coilovers is ride compliance; my 12/8 Function S rides WAY better than my old H&R Sport/stock shock setup. I think the same spring rates on a Koni yellow/GC setup would be close to unbearable on the street.
Old Oct 9, 2002 | 11:47 AM
slowassR's Avatar
Tomcat - what other mods do you have?
Old Oct 9, 2002 | 12:00 PM
Mugen Mike's Avatar
I agree
Old Oct 9, 2002 | 01:59 PM
Sam's Avatar
Sam
Default Re: Type R suspension upgrade (kengs)
How is lowdown compare to stock??
Old Oct 9, 2002 | 09:47 PM
r980923's Avatar
how long those aftermarket shocks can last comparing to stock dampers?
Old Oct 9, 2002 | 10:03 PM
disordeR's Avatar
Default Re: Type R suspension upgrade (r980923)
not as long. many aftermarket coil overs need to be rebuilt well under the lifetime of your OEM shocks.
