hatch hesitates and bogs - cylinder 1 does not change color on header
Old Jan 23, 2012 | 03:33 PM
JdmJah's Avatar
Icon2 hatch hesitates and bogs - cylinder 1 does not change color on header
I just installed a full catback exhaust system with headers and straight pipe . and i notice all cylinders except for cylinder one change color on the header . and it get hot but not hot as its supposed to be because my other ports of the headers are golden except for the cylinder one part of the header . my car also hesitates or bogs a lil and jerks when im driving every now and then. so i brought fuel injector cleaners thinking my injector might of been clog but . still has the problem any suggestions Ht ?
Old Jan 23, 2012 | 04:02 PM
Former User's Avatar
Default Re: hatch hesitates and bogs - cylinder 1 does not change color on header
What car/engine? Please read the forum rules.
Does cylinder 1 have fuel, spark and compression?
Old Jan 23, 2012 | 04:14 PM
JdmJah's Avatar
92 cx d15b sohc engine the car runs and drives i didnt really do test on the spark or compression yet how can i do the test to see if its getting fuel ?
Old Jan 23, 2012 | 04:20 PM
You can listen for whether the fuel injector clicks, or even better remove the fuel rail to see whether the injector sprays fuel while cranking the engine.
Also test for bright white spark at cyl 1.
If both above are fine, then compression test the cylinders.
Old Jan 23, 2012 | 04:23 PM
JdmJah's Avatar
ok will thanks ron
Old Jan 23, 2012 | 05:13 PM
JdmJah's Avatar
well i realize my number one cylinder spark plug wire has spark and the spark plug is good so . i just added some mystery oil and restore injection fuel cleaner bottles into the gas . i didnt take off the fuel rail yet i figure i try these injector cleaners first . i took cylinder spark plug wire off the cylinder number 1 and the idle didnt change but on the other cylinders it did so that means cylinder one is not working ???
raverx3m
Apr 16, 2013 06:13 AM
mouab18c1
Oct 1, 2012 08:40 AM
mattmanNL
Honda Civic (2001 - 2005)
Aug 7, 2012 06:01 PM
Calvinator
Jul 21, 2006 02:29 AM
fire7882
17
Jul 13, 2002 07:29 PM
