front wheel bearings spin in the knuckle??
Old Jan 23, 2012 | 03:05 PM
blackeg's Avatar
Default front wheel bearings spin in the knuckle??
so i dont know whats up with this but ive had it happen to myself and my buddys car in the past year. the whole bearing is spinning in the knuckle instead of just the inner race spinning with the hub.
does the weight of the car keep it from happening when you are driving? im getting a little tired of pulling the knuckles off and replacing the bearings. btw they are installed properly with a shop press and then c clipped in place. this happening to anyone else?
Old Jan 23, 2012 | 03:17 PM
turbohatch96y7's Avatar
Default Re: front wheel bearings spin in the knuckle??
It must have spun prior and bored out the housing theyre not supposed to spin
Old Jan 23, 2012 | 03:41 PM
hondatech8798's Avatar
ya that's not supposed too happen. either the old bearing had spun and kinda bored it out like mentioned above, or it's not the correct size bearing... if the bearing is the correct one it's time too replace the whole knuckle.
Old Jan 23, 2012 | 03:46 PM
blackeg's Avatar
bearings are oem so they are the right size
Old Jan 23, 2012 | 04:01 PM
Yup whole knuckle.
they're like 50 bucks at scrap yards.
Old Jan 23, 2012 | 04:43 PM
fcm's Avatar
fcm
Old Fart
538-2 Hub W/Spindle Fwd Car $21.99 Core $2.99 at your local PicknPull, unfortunately the closest PicknPull to the OP is in Virginia Beach. 94
Old Jan 23, 2012 | 05:19 PM
Yeah I usually hagle em for the whole assembly from the camber arms to the lca.
Just say you found it cheaper and they'll make the sale.
Old Mar 18, 2021 | 05:50 PM
brian980's Avatar
When I replaced my front left bearing and pressed the hub in, the entire bearing would spin inside the knuckle as I turned the hub with my hand (with a good bit of force), as you described. But of course this was with no wheel and the car jacked up, and I probably put too much grease inside the knuckle before pressing the bearing. I assume the bearing is working fine with the weight of the car down but if not I at least can't tell that's happening because everything is silent now. The good thing is that if it was the previous bearing boring inside the knuckle, at least the grease (Lucas oil X-TRA Heavy Duty) is acting as a good padding to keep the new bearing from moving side to side and causing further boring.
Old Mar 22, 2021 | 11:51 AM
civic-steve-94's Avatar
You should never use grease when installing bearings into knuckles or hubs into bearings. They are what is know as an interference fit and should be difficult to assemble.
ki11r0y1086
15
Nov 7, 2018 10:18 PM
76 camaro car
Jan 19, 2015 09:28 AM
Bnjmn
Sep 20, 2005 03:43 PM
nxda9
Sep 2, 2005 07:25 PM
ViZ
Feb 11, 2005 07:52 PM
