more boost on a turbo? how to build the block?
i was wondering on how to build the block so that the engine can hanlde more boost on a turbo set up.
95 gsr what can you do so it is safe to have more boost?????
New pistons, rods, sleeves, bearings, arp studs, and LOADS of tuning with a standalone and you should be just fine
you might want to get an after-market crank to if you got the money have it machined so that the new crank will be perfect! and all the above!
Nisif
Aug 30, 2012 09:55 AM
