95 DX only starts when "FREEZING" outside.
I've posted problems on another thread before but never found a solution. 95 dx will start and run for 2 to 3 seconds and then die. Just to update anyone reading this: I've changed main relays and done all the spark test and checked for voltage everywhere it's suppose to be and not be. I've changed fuel filter as well. What I have noticed is that if the temp outside is below freezing for at least 2 days; the car will start normally and can be driven all day and will crank everytime. I've swapped relays to make sure both were good and it cranks everytime. I took it to get fuel pressure test done when it was running and it was around 40 psi at idle and would drop to around 35 to 37 under throttle. I've let the car run with the heat blasting inside the car and it will still start time after time. Now if the temps warm up outside for more than 2 days then it will go back to previous symptoms. It seems as if something on the vechicle has to be or get extremely cold to work and whatever it is will stay cold for a while until outside temps warms it up. Is the fuel pump affected by cold temps? I do not own a fuel guage so I dont know what pressure is when it's not cranking and running. Could any other electrical part be affected by extremely cold weather?
Yes. I always have spark. I have not replaced ect sensor. It seems as if it's running out of fuel because after the pump primes and it starts for the 2 senconds; it will not start again unless I turn switch back to the position where the pump has to prime again. It will just turn over but not start. If the sensor is bad would it allow
the vechicle to start after its been driven for serval mile and everything under the hood should be well heatd? How is the sensor tested? Thanks for your response.
Really appreciated.
Really appreciated.
On the 4 cyl 5th gens for the ECT test you will be testing the resistance....
And by what I can tell, you live in AL....so I guess this car starts 6 days out of the year?
Hey, I've spent lots of time in LA (lower Alabama)...loved it.
Can you humor me. Next time it is warm out, spray carb cleaner into the TB-open the butterfly- and see what happens.
Since you have noce blue spark all of the time, then something with the fuel system is up.....but I'm guessing you knew that
Those things are like 25 bucks at any auto parts store. If you really don't want to test it, just replace it. Even if that's not the problem it's atleast very replaceable.
Finally got around to checking the ECT sensor or should I say "breaking" it.
Anyway since I broke it I had to replace it. Still did'nt solve my problem though.
I finally broke down and took it to the mechanic. He did a dionagstic and it showed nothing abnormal. He swapped the ecu anyway and car started right up. He keeps a couple of ecu test units around for certain cars and luckily mine was one of them. I convinced him to sell me the ecu and went ahead and had them change timing belt and drive belts too. Thanks to all who tried to help.
TrackRat
Aug 8, 2010 01:28 PM
vanilla gorilla
Mar 9, 2009 09:54 AM
