Top Fuel Power chamber
hello. Anyone tested this Power Chamber from Top Fuel? base on the website: http://www.nengun.com/top-fuel/power...type-ii-carbon
Claim that it can help increase some horse power. anyone try it before? thank you
You can get a K&N filter for it.
You should read this if you haven't.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/guide-answer-common-question-just-bought-civic-how-do-i-make-faster-2915974/
I did search some infor. The velocity stack really smooth the air flow. but most is a long pipe and the velocity stack. above picture you can see the C.fiber Air Ram is bigger then smaller again to the intake. if it plus the velocity stack will it be gain hp or the straight pipe is the smoothest air flow?
the picture is current i'm using. if add the stack flow will be ok too?
ioi = crying
If from my exist ram( i don't know what type of shape air ram) Let's call it S- shape air ram turn back to stock but with k&N filter will it be better?
It won't make a damn bit of appreciable difference. get a $10 pipe, k&n filter, and be done. There is no magic combo of intake/filter that will net you an appreciable power gain unless there is also air being forced above atmospheric pressure down you're engines dirty mouth.
If more cleaner from dust and rain water drop.... stock is better is it?
some people here http://www.ek9.org/forum/honda-integ...mugen-box.html
claim that they gain power and responsive here
It's all BS. If you want more power boost the engine or swap it out with a bigger one. All these things you keep posting about are absolute wastes of money and are designed to get people like you salivating and opening your wallets. None of these bolt-ons make any real power. I don't care what anyone in the Honda community tells you or what you see an anyone's funky online articles or fanboy magazines, you may HEAR a difference but you CANNOT FEEL IT and it DOESN'T MAKE YOU ANY FASTER. If you think that you actually will feel 10 horsepower and 5 ft-lbs of torque then you are delusional. You'll get your eyes opened when you slap all that stuff on, stage up next to a Prius, and it leaves you cold at the line. I don't care if i comes from Japan or Mars, don't waste your money on it.
