Civic 4wd Axles?
Old Jan 23, 2012 | 07:31 AM
BIGef's Avatar
Icon3 Civic 4wd Axles?
Will a Civic wagon 4wd axles fit 89 civic hatchback?
Old Jan 23, 2012 | 07:04 PM
awdracer6's Avatar
Default Re: Civic 4wd Axles?
That would be awesome!!! BUMP
Old Jan 23, 2012 | 08:18 PM
crxguy406's Avatar
Are you asking if the front or the rear set of axles on the 4WD will work in the hatch?
Old Jan 23, 2012 | 10:04 PM
BIGef's Avatar
Im asking if front axles will fit the hatch. Drive side or passenger.
Old Jan 24, 2012 | 04:34 AM
crxguy406's Avatar
Doesn't look like they will. The wagons have equal length axles where yours does not. Besides the length, I think the wagon axles had 2 more splines.
Old Jan 24, 2012 | 06:17 AM
jlicrx's Avatar
that is correct - 4wd wagon uses the same axles as the JDM CRX/Civic Si models with the DOHC ZC engine, transmission and intermediate shaft - unequal length axles are 26mm diameter with 25 splines on transmission end - equal length are 28mm diameter with 27 splines - the 4wd wagon intermediate shaft will not work with DOHC ZC transmission, only with the 6-speed wagon transmission
Old Jan 24, 2012 | 06:45 AM
BIGef's Avatar
Thanks guys for the info
hondamaker1211
Aug 23, 2010 05:25 PM
blake22
Feb 18, 2007 06:59 AM
