Integra LS + P06 ECU - How to set up basemap in Crome?
I want to remap my Integra LS from scratch (it's turbocharged) with a P06 ECU. It's been a while since I've started from scratch so I'm not sure what the exact procedure is.
The base car is an Integra LS. The ECU in it now is a P06.
Crome lists the following maps to start with:
-P28 USDM Civic D16Z
-P30 JDM Civic B16A
-P30G EDM Civic B16A2
-P72 USDM B18C1-3
I know at some point I need to shoehorn the stock LS map into Crome but I'm not sure what I do with the fact that I'm using a P06 ECU which isn't listed in the Crome base rom menu.
Thanks in advance for the help.
-P30 JDM Civic B16A
-P72 USDM B18C1-3
All you need to do is pick a map (just use a B16 one) and disable VTEC (you can just set the engagment point higher than your rev limit) and just tune the "low cam" maps. Simple as that.
So I can assume your p06 ecu is already chipped correct? And you have all the proper hardware?
I have a Ls Basemap that I used on a customers b20 and it ran really smooth. If you want then PM me your email address and you can start from there.
