Shaky/Vibrating Steering Wheel
Old Jan 22, 2012 | 04:25 PM
Da_1991's Avatar
Default Shaky/Vibrating Steering Wheel
I recently did balancing on all my tires and I still get a shaky/vibrating steering wheel while on the freeway going 60+. I was thinking it might just need an alignment done or rotating the tires might help out. Any suggestions and how I can check them myself? Thanks.
Old Jan 22, 2012 | 04:27 PM
bryan24207's Avatar
Default Re: Shaky/Vibrating Steering Wheel
i had same problem till 2 days ago, alignment fixed it up and now my car drives straight, no shake or anything..and now i dont have to buy front tires every month lol
Old Jan 22, 2012 | 04:37 PM
Da_1991's Avatar
Cool cool. Was thinking about getting that alignment done after I dump my teg down some more . Btw saw your thread, nice teg and good luck on the build.
Old Jan 22, 2012 | 04:38 PM
bryan24207's Avatar
thanks, and yea thats why i went threw so many tires, i didnt want to get my alignment till i had rims n tires and was as low as i was gonna be going
Old Jan 22, 2012 | 06:51 PM
2kdb8's Avatar
I'd take a look at your outer tie rods. Bad ones can cause said symptoms. I had the same issue and looked at my tie rods and not only where they leaking grease but really loose that could be moved around by hand. I purchased a front end Kit on ebay, included inner tie rods, outer tie rods, lower ball joints and sway bar links. After installed car ran solid with no more vibration and steering felt more firm. Not saying you have to replace everything I did, but should check them out.
Old Jan 22, 2012 | 07:03 PM
2kdb8's Avatar
Plus these are items to look at before an alignment because another alignment will be needed if anything needs replacing. I've worked as a techncian for Toyota in the pass and with my experience vibrating and shaking are due to a bad balanced tire or bent wheel or bad steering parts such as tie rods. A bad alignment will mainly cause pulling, crooked steering wheel and of course worn tires.
Old Jan 22, 2012 | 07:22 PM
DirtyDA9's Avatar
How old are your tires? Sometimes old tires get flat spots, even if the balance is spot on it will vibrate, if they are new, then whoever did the balance messed up.
Old Jan 24, 2012 | 07:39 AM
Da_1991's Avatar
Ahh I see thanks 2kdb8, I'll be sure to check those out. I actually had a (minor) leak coming from under the coolant/power steering fluid container area when I changed my oil and yet i couldn't really find the source of the leak, but it also stopped after I set the car back down. And DirtyDA9, my tires are near new, still with at least 90% tread. The balancing actually helped when I had got it done, but I guess I should get it rebalanced at another shop after checking out the other things.
apbtwhiskey
21
Sep 16, 2013 05:27 AM
jimmy051702
Suspension & Brakes
Mar 6, 2012 03:20 PM
Baron55
Jan 2, 2007 12:48 PM
sikcrx80
Aug 25, 2003 01:52 AM
project_DC2
Jan 30, 2002 09:46 PM
