cheap wire tuck harness?
Old Jan 22, 2012 | 12:55 PM
(eg)upyours's Avatar
Default cheap wire tuck harness?
does anyone know any place i can get cheap wire tuck harness for cheap?
Old Jan 22, 2012 | 01:22 PM
turbohatch96y7's Avatar
Default Re: cheap wire tuck harness?
What kind of tuck?? I can do it for you cheap if usend me your harness pm me.
Old Jan 22, 2012 | 01:23 PM
I might even be heading down to imperial beach tommorow.
Old Jan 23, 2012 | 02:46 AM
im looking for a full wire tuck, just like chase bays and rywire. do you have any picture of your work?
Old Jan 23, 2012 | 02:57 AM
i would really love to keep my old harness in case i sell the car, i was just wondering if there's other guys like chase bays and rywire
Old Jan 23, 2012 | 04:43 AM
grumblemarc's Avatar
The Grumpiest
No such thing. Especially since no one knows what your definition of cheap is.
Old Jan 23, 2012 | 06:53 AM
I don't got pics but I am a electric forklift technician. I work on systems 100 times more complex than a simple distribution board and harness. Pm me I got pics of my harness I did. I'm not too sure how chase bays look but I doubt you need military spec sleave.
Old Jan 23, 2012 | 06:55 AM
The Grumpiest
Well if you get into it lemme know. Might be interested in picking up a harness.
Old Jan 23, 2012 | 08:46 AM
For,sure I'm intrested in knocking a couple out. What kind of harness you have? (Obd1 2 ) what are you keeping
Old Jan 23, 2012 | 08:56 AM
Dc4LsTeG's Avatar
EK9
X2 send me pics of what you can do with an engine harness. Can you do it with the milspec plug?
Old Jan 23, 2012 | 08:58 AM
The Grumpiest
I would be keeping everything. OBD2a
Old Jan 23, 2012 | 09:26 AM
Dc4LsTeG's Avatar
EK9
Old Jan 23, 2012 | 09:56 AM
I would have to look into a milspec plug. I don't have a chassis to make the measurements. But a tucked harness sleaved I can do. Pretty easy.
That's. A close up of my harness. It a gsr with everything under the intake manifold.
I'm thinking of making a bracket out of aluminum to hold the harness in place. And bolt it to where the stock catch can bolts. Using longer bolts of course.
Old Jan 23, 2012 | 12:05 PM
The Grumpiest
Lemme source a spare harness and get back to you.
Old Jan 23, 2012 | 12:12 PM
98civdx's Avatar
Master Detailer
I would have to look into a milspec plug. I don't have a chassis to make the measurements. But a tucked harness sleaved I can do. Pretty easy. [IMG]
Harness by dense147, on Flickr[/IMG]
Whats up with the random wires runing arond? Or where you still tucking the harness in that shot?
Old Jan 23, 2012 | 01:10 PM
Yeah tthats not the final harness. I still had a couple sensors to sleave. That was like 70 percent done
Old Jan 23, 2012 | 08:30 PM
how much do you thing you will charge if i get you a harness?
Old Jan 23, 2012 | 08:49 PM
JustOneOrTwoPosts's Avatar
do you use the original wires/plugs or new ones?
Old Jan 23, 2012 | 08:53 PM
98civdx's Avatar
Master Detailer
That is what I was thinking.
Yes, and yes. You can use your old harness, or you could make a new one if you really wanted to.
Old Jan 23, 2012 | 09:04 PM
I know you can. I was specifically asking turbohatch if he uses the old stuff or new items.
Old Jan 23, 2012 | 09:08 PM
98civdx's Avatar
Master Detailer
oh
Old Jan 23, 2012 | 09:32 PM
It depends on how cheap you want to be. I can do whatevers needed. My advice if the wiring on your old harness is fine and doesn't have high resistance don't change it. I can paint connectors or just clean em.
I can re run your whole engine harness to accept what your using. I have a gsr on my stand now so that will be easy for any vtec harnesses. And I got my single cam y5. In my hx for single cams.
What I did on my harness is pull all the extra wirfe to the ecu side incase anything needs to be extended later.
saysar169's Avatar
This looks extremely good.How much for a gsr motor in a ek?
Old Jan 23, 2012 | 09:33 PM
Pm me for price I don't think that can be discussed here.
How much does a rywire harness run?
Old Jan 24, 2012 | 02:39 AM
i wanted mines shrink wrap and braided, price for with and with out core harness
shipped to 92126
