1996 accord jumps when switching gears
1996 honda accord 2.2 automatic like to jump when switching gears. It mostly happends when i switch from park to reverse.
I just switched out the transmission, but even in the other transmission it would do this. The new transmission was for a prelude. It came with all the sensors so i left them in.
Is this a possible bad sensor?
If it did it before and after you swapped the transmission then it's probably not the sensors unless both are bad. It could be something in the connection or harness. Possibly a problem in the transmission computer or connection also.
jdmcertified909
Sep 28, 2011 04:53 PM
