Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Valve locknut size?
Old Jan 22, 2012 | 05:58 AM
BLKFLSH's Avatar
Default Valve locknut size?
I am attempting to make my own valve adjustment tool, using a socket, screwdriver, and wrench. In making my tool, I would have to drill the inside of the socket a little, for the screw driver to fit right. Then machine the outside of the socket to fit the wrench, so I want to make sure I'm using the correct size socket. I thought the locknut was 10mm, but the Helm manual says 9 x 0.75mm. Which is it? Thanks
Old Jan 22, 2012 | 06:19 AM
MSchu's Avatar
My Name is Nobody
Default Re: Valve locknut size?
I guess it might depend on the motor... Most I have seen are 10mm
Old Jan 22, 2012 | 07:02 AM
webbpaul's Avatar
i know mines 10mm
Old Jan 22, 2012 | 07:14 AM
BLKFLSH's Avatar
J30 (03V6). I hope it's 10mm, cause I already drilled the inside of the socket.
Old Jan 22, 2012 | 09:02 AM
BLKFLSH's Avatar
OK guys. This is what I created. I drilled the inside of the 10mm socket, so that the screwdriver would fit through it, without much play. Then filed opposite sides of the socket, so that the 14mm wrench would fit tightly on the top of the socket. I think it will work great. Any opinions?
Tiger_Fit2007
Aug 16, 2013 05:17 AM
lkailburn
Aug 21, 2004 10:13 PM
98type_r
Apr 2, 2003 11:25 PM
b18bvudoo
Dec 21, 2001 03:20 AM
