ef d16y7 swap!
Old Jan 21, 2012 | 06:34 PM
jackhatch's Avatar
Default ef d16y7 swap!
i have a 91 civic hatchback with a d15b1 stickshift. i have a d16y7 (non v tec) engine nd complete harness from a 97 civic lx id like to swap into the 91. what parts or mods will i have to do to make this work.?
Old Jan 22, 2012 | 05:16 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: ef d16y7 swap!
You won't need the harness from the new motor. Just swap over the intake and exhaust manifolds over to the new motor. Also reuse your d15s alternator and distributor. When putting the engine in take the drivers side mount (the one that bolts to the block itself), and swap it over to the Y7. That's about it. You'll have an extra sensor by the crank pulley on the Y7 just ignore it. The only wiring youll have to do is the fan switch. The d15 is on the back of the block (two pin with a green center), take those two wires from there and wire it to the Y7s fan switch on the thermostat housing. The wire order doesn't matter. All the other head and block sensors are plug and play.
Coupe16vt
Dec 31, 2017 03:22 AM
2001s4
Jul 20, 2014 06:02 PM
93'colttsi
Sep 24, 2007 01:30 PM
fin781
Mar 30, 2007 08:14 AM
