Headlight problems!!!!!
Old Oct 8, 2002 | 08:10 PM
bLuEciVicGuY's Avatar
Default Headlight problems!!!!!
Why is one of my lights very low when I turn them on.When the lights are on, one of the turnin signals brink hella quick and the other side is normal.I check the bulbs and none of them are blown.And also these are projectors headlights I'm talking about.If anyone know why this is happening let me know.Thanks in advance.
[Modified by bLuEciVicGuY, 5:10 AM 10/9/2002]
Old Oct 8, 2002 | 08:22 PM
dom93hatch's Avatar
Default Re: Headlight problems!!!!! (bLuEciVicGuY)
I'm not a lights guy, but have you checked the wires? Maybe there are damaged wires.
Old Oct 8, 2002 | 08:51 PM
2camsaam's Avatar
Default Re: Headlight problems!!!!! (dom93hatch)
when you say that the lights are really low, do you mean the brightness of the light projected or the height of the light that is being aimed?
Old Oct 8, 2002 | 10:09 PM
Default Re: Headlight problems!!!!! (2CAMSAAM)
Yes I mean the brightness of the light.
Old Oct 9, 2002 | 12:03 PM
PnX-R's Avatar
This is happening because you or someone else added projectors on your car. Whoever did probably didn't do too well of a job wiring them. I bet you that the problem either has to because the lights are wired in series, which I highly doubt, or because of excessive resistance. Try checking the connections to the light's sockets and see if they're corrodded. That seems to be the only answer I can think of. That's because you did say that one light is brighter than the other and that one turn signal blinks faster than the other. Good luck..
CPreston
Lighting
May 21, 2009 11:35 AM
Mfoehrkolb
Sep 22, 2008 05:56 PM
simplypinoyy
Jul 12, 2008 11:59 PM
DinDinh04
Lighting
Feb 6, 2008 03:03 PM
xxnickpxx
Dec 26, 2007 12:43 PM
