Classic Hondas All Pre-1988 Hondas.
1984 AH civic. blown the head gasket four times!
Old Jan 21, 2012 | 01:46 PM
E-AH driver's Avatar
Default 1984 AH civic. blown the head gasket four times!
my almost immaculate AH civic has blown the head gasket four times in its life, and the last one just a thousand ks apart! HELP!!!
Old Jan 21, 2012 | 03:53 PM
RuskeR's Avatar
Default Re: 1984 AH civic. blown the head gasket four times!
When you replace the head gasket do you just swap in a new one? Have you checked the head to see if it's warped at all? It may need to be looked at if the car has overheated at any point.
Old Jan 22, 2012 | 06:30 AM
E-AT_me's Avatar
head or block must be warped. pull them both and get them straight-edged and shaved to whichever is bent..
Old Jan 23, 2012 | 12:23 AM
already had the head planed last time, has almost overheated once since. due to a buggerd thermostat
Old Jan 23, 2012 | 12:44 AM
jmarshall098's Avatar
Just check out if your cooling system is in shape or not? Because one of the main reasons for blowing of the head gasket is over-heating of your engine.
Preignition and detonation can also cause damage to head gasket. But again the above two phenomena occur due to engine overheating. So first and foremost just check the health of your cooling system.
Old Jan 23, 2012 | 03:53 AM
E-AT_me's Avatar
ok, the block is good. how about the head? is that warped?
probowler2286
Mar 29, 2015 06:54 PM
flozella
Aug 30, 2014 07:20 PM
fireman mike2288
Mar 13, 2008 10:35 AM
lovnmysol
May 19, 2005 06:35 AM
filetofit
Aug 13, 2002 08:49 PM
