HELP
Old Jan 21, 2012 | 12:31 PM
apougnet's Avatar
Default HELP
obd 1 p13 ecu. codes 21, 22, 10. codes 21 will come on then go off then 22 will come on then go off then 21 will come back on. i have gone through oem flowcharts for both and everything checks out. checked voltage and resistance. both within spec. motor is a h22 swapped into a ek civic. anyone have any ideas on why this is happening? any help would be greatly appreciated
Old Jan 25, 2012 | 03:42 PM
apougnet's Avatar
Default Re: HELP
bump
Old Jan 25, 2012 | 04:08 PM
Dc4LsTeG's Avatar
EK9
Default Re: HELP
Are you sure your vtec is wired right? Are you low on oil?
Old Jan 30, 2012 | 01:52 PM
apougnet's Avatar
Default Re: HELP
im almost positive that it is. im not low on oil but a bit over full. could that possibly cause it
Old Jan 30, 2012 | 02:32 PM
turbohatch96y7's Avatar
Default Re: HELP
Does your speed sensor work? I can't remember exactly what the codes descriptions are post the details
How sure are you on the wiriing to the vtec solenoid and pressure sensor
siracer1750
19
May 20, 2012 04:48 AM
TNRspeed
11
Jul 18, 2008 12:26 PM
JsSIR
Jul 14, 2008 08:14 PM
vtecftw
May 6, 2007 07:48 PM
b16a_ef9
May 4, 2005 04:11 PM
