Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Bad motor mount? With pic's!
Old Jan 21, 2012 | 10:42 AM
Jou64's Avatar
Default Bad motor mount? With pic's!
Any help would be much appreciated. 208 civic coupe. Car has been vibrating in reverse, idle and low speeds. Did some research and narrowed it down to the motor mounts. Wasn't sure exactly which one though. Did the test where I watched the engine move while someone was in the car but could not tell which mount was bad. The engine did move a lot. Replaced the lower mount last night but the vibration is still there. I just removed the upper passenger side "dog-bone" but not sure if its bad or not. Here are a couple pics of it.
Old Jan 21, 2012 | 10:50 AM
Dc4LsTeG's Avatar
EK9
Default Re: Bad motor mount? With pic's!
Doesn't look like it. Have you checked your rear mount?
Old Jan 21, 2012 | 11:02 AM
Jou64's Avatar
Thanks for the quick reply. Rear mount? I can only find three. The lower (already changed), upper passenger side and upper drivers side.
Old Jan 21, 2012 | 08:00 PM
97emsedan's Avatar
the rear mount might tie the tranny to the sub frame... look from below...
.I.Need.Money.
Suspension & Brakes
May 4, 2007 10:14 AM
mike93eh
Jul 29, 2005 02:28 PM
onyx00
Sep 24, 2004 01:00 PM
mattL
May 25, 2004 12:32 PM
Ideal
Aug 2, 2002 02:08 PM
